Lighting 40x40x14 Will this work?
spam4us
In another thread Platonic Solid detailed the layout below for a garage that is slightly larger than mine.
My garage is 40x40x14 with three doors that are 10w x 12H across the front.
Will Platonic Solid's layout work if I install the lights spaced at 4ft 15ft 25ft 36ft each way?
How much different would the FCs be?
Would lights with a diffuser be more pleasing to the eye as far as glare is concerned?
I looking for a surface mount light.
Thanks
Qty.16 GreenTek GT-H2-110W 16,400 Lumen sold by greenlightdepot for $85 (link) = $1360.
It does not have surface mounting brackets available, but does come with “V” hooks and chains.
GreenTek is a relabeled James ZY-H2-110W fixture also sold by ledlightingwholesaleinc for $95 (link)
Dialux PDF Report (link)
Avg yield @ 30” workplane = 101fc
Total Lumen output: 262,528 lm
Total Wattage: 1760W (14.67 Amps @ 120VAC)
images linked to larger pics
spam4us
Thanks Platonic Solid. Your expertise and willingness to go above and beyond to help others on this site is appreciated.
When you say 10' x 10' spacing does that mean that I start 5 ft from the wall then every 10 ft from there? like this
(0ft.................................................40ft)
(wall...5ft........10ft......10ft.....10ft.....wall)
Thanks
Platonic Solid
CT-USA
Yes spam4us you got it, but since 40 x 40 is usually the exterior dimension. Do 10' x 10' fixture center to fixture center spacing and center it.
