Am I missing something here? It seems that the pricing per lumen is actually not all that good. You're getting about 3000 lumens for $25 or so (.008cper lumen). You could buy a 4 lamp commercial troffer for about $45 and 3200 lumen bulbs for $2 each 12,800 lumens for $53 (.004c per lumen)
Also, based on what I have read most recommend around 100 lumens/sqft which proposed installations fall well short of here.
Not trying to stir things up, just trying to see where I am off.
Thanks
Chris
http://www.lowes.com/pd_163642-337-...troffer&pl=1¤tURL=/pl__0__s?Ntt=troffer
39.99
Is your fixture per bulb including the bulb? It seemed to me that most of the bulbs were in the $25 range.
You can get 6000k t8's if you like that color.
)...Bringing this back from the dead. I copied this exact setup using 16 105w CFL in a 42 x 50 building. I just got them fired up and I love the light but I am having a problem with the breakers buzzing. I am being told you may have to allow for much more amperage in your circuits. I was wondering if anyone else has had the same issue?
details here
http://garagejournal.com/forum/showthread.php?p=1568430&posted=1#post1568430
I got a email about this thread.... just thought I would update everyone about my experiances with my choices .....
NO Regrets at all.... these rock.... and still rock.. I have yet to replace a bulb.. ( now watch I will have to replace)...
They still shine, and still every time some one new comes over they comment about the lighting and how bright it is....
Only complaint would be winter.. they take a few min. to warm up... not a issue with me...
May consider using a higher quality switch too. At least check out your connections.
I have learned to turn on the radio and just live with it. Mine are on 2 20a breakers (8 each) If I unscrew 1/2 the bulbs the buzz goes away. I have had lots of comment on how bright it is in there. This was when I was still waiting on my last three bulbs to come in off backorder.It sounds like you may need to split up the circuits. You don't say how many circuits the 16 lights are on. If they are all on one, then you are nearing the 80% max allowed on a lighting circuit, based on wattage alone. Given the power factor issue with these lights, I would split the circuit in half and see what happens, I'll bet the buzzing goes away.
Charles
So based off whats gearhead said "he unscrew half and buzz went away". So then maybe to be on the safe side 4 to 5 fixtures per breaker/switch.
You should split up the circuits. Buzzing of the breaker is certainly not good for it. Turning up the radio is like hearing the neighbor being murdered and turning up the TV so you cannot hear it, you ARE killing that breaker.
Need to fix the problem. Might save you from problems down the road.
You don't want all lights on one circuit anyhow.
Charles
I just got home from Farm and Fleet, they have a sale on the 68 watt CFL (300 watt equivalent) for $14.99 each. They are only 2700K (with 4200 lumens) but some people prefer the soft lighting over the harsher 5000K type.
They only had one left, but I stopped at the customer service desk and asked if they would give me a rain check at that price and they said yes, so I ordered another 10.
Jim
I would be interested to hear what you think about the color temp when you install those. I know some object to the warmer side of the spectrum but for me it's no biggie, but I would like to hear what you think.
Our local Home Depot had the 300 watt equivalent CFLs for 16$ regular price. I opened the box and tlet me tell you that these things are comical. It's just like a regular sized lamp CFL but scaled up 5 times, this thing is freaking huge.
The operating temperature was down to like 20 above zero but the next size on the shelf, a 150 watt equiv for 10$, had an operating temp of 14 below zero.
I really dislike the slow slow slow warm up time of my CFL par floddlights in the recessed cans inside my home even at 65 degrees they glow purple for several minutes.
Adjustable Lamp Head : No
Adjustable hanging length : Yes
Assembled Depth (in.) : 16 in
Assembled Height (in.) : 8.75 in
Assembled Width (in.) : 16 in
CSA Listed : No
Collection Name : N/A
Color/Finish Family : Satin Nickel/Chrome
ETL Listed : No
Energy Star Compliant : No
Exterior Lighting Product Type : Pendant
Fixture Material : Steel
Fixture depth (in.) : 16
Fixture height (in.) : 8.75
Fixture width (in.) : 16
Hardwired or Plug-In : Hardwired
Item Package Type : Plastic Container
Lamp Style : Pendant
Manufacturer Warranty : 5 years limited
Maximum Bulb Wattage : 100 W
Maximum Hanging Length (in.) : 78
Number of Bulbs Required : 1
Pendant Type : Large Pendant
Product Weight (lb.) : 2.88 lb
Recommended bulb type : A
Returnable : 90-Day
Shade Included : Yes
UL Listed : 1-UL Listed
Uplight/Downlight : Downlight
Wattage (watts) : 100 W
I found a similar reflector from Amazon.
I would link it here, but it links to the order page when I purchased.
Amazon - I put "metal light reflector" in search window, result = Designers Edge L-1710 12-Inch Indoor One-Light Downward Farm Light Fixture, Powder Coated
