lighting dilema for newbie
madmanmerc
montreal
Hello, Being new to this forum, I am excited about all the info I will learn. My current dilema is that I have a single 10x20 with a single 60 watt bulb. Seeing that I am planning on doing a complete makeover, I thought i would start with lighting. I was at Home depot today and found for around 50 bucks I can buy an additional fixture, some wire and 2 42watt cfl bulbs at 2700 lumens each and are the equivilent of 150 watts incadecent. My question is will this be sufficient lighting, or will i have to go to fluorecent tubes. What I want is a nice bright garage were I can work on my baby (1970 mercedes coupe) and have a nice even distribution of light. I have a budget of around 200 dollars, although the specialist at Home depot told me I should be fine with the previous 50 dollar option. Any advice will be greatly appreciated. thank you
Madmanmerc
rburke65
Canfield, Ohio
Myself, I would start with 2 eight foot, fluorescent fixtures, with the 4 lamp, T8 lamps. As they say...you should see what your missing. You won't regret going with the above. Good luck and welcome to G. J.
Journaler
Somewhere on this site, somebody posted a link to a calculator that figures out how many of your desired fixture types you'll need.
It was pretty accurate in my case.
You might want to search for that link.
Sparkfarmer
Toronto Canada
If you're walls are not already white then painting them a high gloss white will significantly reduce the amount of light you need. Also looks good.
pattenp
Virginia - USA
Activity ------------------------Illumination (lux, lumen/m2)
Public areas with dark surroundings ---------- 20 - 50
Simple orientation for short visits ----------- 50 - 100
Working areas where visual tasks
are only occasionally performed --------------100 - 150
Warehouses, Homes, Theaters, Archives-------- 150
Easy Office Work, Classes---------------------- 250
Normal Office Work, PC Work, Study Library,
Groceries, Show Rooms, Laboratories-------------500
Supermarkets, Mechanical Workshops,
Office Landscape ------------------------------ 750
Normal Drawing Work, Detailed Mechanical
Workshops, Operation Theatres----------------- 1,000
Detailed Drawing Work, Very Detailed
Mechanical Works -----------------------------1500 - 2000
Performance of visual tasks of low contrast
and very small size for prolonged periods of time - 2000 - 5000
Performance of very prolonged and exacting
visual tasks ------------- ---------------------5000 - 10000
Performance of very special visual tasks of
extremely low contrast and small size - ---------10000 - 20000
