I need help lighting up my small 1.5 car garage, I like to detail my cars and do repairs when needed so i need really good light with no shadow effect. i Have to measure again but i think its something like 18x20x8 so yea its small, but also its a condo in Chicago.
For an urban condo, that's really not too bad. Automobiles (and the facilities to accommodate them) tend to be treated as Red Headed Stepchildren in such environments.
whats the best placement and what fixture type should i get. i will get more photos soon since it was pouring outside when i took these.
Given the relatively low ceiling, you're going to want as much dispersion/diffusion as you can get. Furthermore, placing (most of) the lights directly overhead will likely be counterproductive (or at least rather wasteful), since the car itself will then form a large shadow. That said, the SIDES of those soffits shown in the pictures look like near-ideal mounting location for fluorescent strip lights. Something like this:
http://www.homedepot.com/p/Lithonia-Lighting-2-Light-Utility-Light-3348-2L32W-WRAP/100654395
Would be cheap and effective. The polycarbonate lens will not only provide some impact protection and give a more "finished" appearance than open-tube strip fixtures; it will also help diffuse the light -- which in turn will help cut down on shadows (as will keeping the walls & ceiling painted bright white). And being a two-tube fixture, you can use enough of them to basically ring the space, without being too deep into "overkill" territory. I would still suggest wiring them in at least two (maybe more) separately switched "banks", so that when you don't need gonzo brightness, you don't have to put up with it (or waste the energy needed to create it). Finish it off with one (maybe two) additional one(s), mounted more or less in the middle of the ceiling to act as your (again, separately switched, and possibly tied into the garage door opener) casual "walk through" lighting, and maybe one more directly over your workbench, and you should have it knocked.
how high are you ceilings? i was looking at maybe (4) 4ft t5 or (2) t5ho 8ft I need bright
More than "bright", you need "evenly distributed". Yes, you'll still want a certain total light output (typically expressed in in Lumens); but concentrating that into two (or even four) fixtures will create rather "spotty" lighting, especially given your low ceilings. Further, by the time you get enough of those two-tube fixtures (or similar) installed to completely obviate the shadowing issue, overall brightness will NOT be a problem!
Finally, I strongly prefer the four-foot types, as they tend to offer more placement flexibility than 8-footers do. And besides, at this price, you can afford to use (at least) twice as many of them. Also, the four-foot T-8s will not only be cheaper to buy, but also cheaper to feed over the long haul, at least once you consider bulb-replacement costs.
