Lighting for fabric arch building?
Nuccio
Northern NJ
I am building a 28'W x 48'L x 18'10"H fabric arch shop. It also has braces at 16'10" going across the arch's. i was thinking mounting 4 - 6 led 150W high bays lights. What are thought? recommendations?
N
Nuccio
Northern NJ
Please post pictures of something similar and plans if you have them.
There is a picture of the actual building in the OP. it is basically metal arches 4' on center that will be covered with fabric and the end walls will be framed and covered with metal siding. if you look at the pic above you will see the cross braces that are 16'10"H the peak of the building is 18'10"H there is about 10'-12' between the cross braces where it intersects the roof arches. That is where i would like to hang to lights 2 rows down the left and right side of the braces so basically 12'x12' pattern
