Lighting help on new 4 car garage
beldar
OK
Hi,
So I'm building a new house with hopefully a great garage/shop. Looking for light layout advice.
Its a 3 car with 3rd bay having a tandem 4th bay. 23' x 32' with 4th bay being an additional 20' deep. 10' 6" ceiling. 18' x 8' main door, 8' x 8' doors on front and back of bay 3 and 4. I've linked a layout of cars/toolboxes/bench and detailed blueprint PDF below. I can PM the DWG if anyone's interested.
It seems the LumeGen 2ft.-10,400 Lumen - 80 Watt - Dimmable (link) is the way to go. No real budget constraints, so I don't mind coating it with lights, I just need to know where to install them.
I'm guessing a general lighting layout will be fine for 2 car part, but what's best for brighter or more lighting in 3rd and 4th bay where I will be doing most work? Maybe there will be enough light with general layout everywhere?
Work in left 2 bays will be light auto maintenance (oil changes, brakes, etc), Woodworking. Work in bays 3 and 4 will be woodworking, Electronics (soldering, etc), and other bench work.
Any help would be greatly appreciated.
Long time listener, first time caller here :)
Detailed garage/house blueprint PDF (link)
Garage car/tool/bench layout (link)
75gmck25
Alexandria, VA
If you just install switched ceiling receptacles in all the possible locations, it will give you a lot of flexibility to set up your lighting. Most of the plug-in lights come with about a 5 foot cord. That gives you the ability to move them around and make final adjustments/additions if you need more lights, or they need to be off in one direction to give the best light. Most of the new LED lights also have such a low current draw that adding more lights will never be a problem.
Since GFCI is now a requirement for all garage receptacles, just add one in the switched line to the lights and put it down on a wall where its accessible for reset.
Bruce
red94chev
Northeastern MD
I have a 30'x42' and one corner of the shop (10"x12" is its own little room with its own lighting. So in the rest of the shop, I just hung 18 of these here and it came out great. https://www.amazon.com/dp/B0728P14FR/?tag=atomicindus08-20
I think they're awesome. Just like 75gmck25 said, they come with short cords and I ran a series of outlets in the rafters for each row. I have most on one circuit and a few on another so I can choose how much light I need at the time (not to mention you can turn individual lights off with the pull cord. I'll try to get some pictures tonight.
beldar
OK
Thanks guys. I had seen those lights specified before for a normal ceiling height (I think), but I could be wrong.
I actually have switched ceiling outlets in my current garage but I have not moved lights in the 11 years I’ve been here. I was thinking hardwired lights would have a cleaner look.
Although with the higher 10.5’ ceiling I may not notice outlets as much.
Red94, how many lights length vs width in your 30 x 42?
Thanks
red94chev
Northeastern MD
Hopefully this picture shows up. The left rear rectangle is a room with its own lighting. And this is with 10' ceilings.
18 total lights. Each on is 4' long, 4100 lumens, and 5000k temp.
red94chev
Northeastern MD
With Tapatalk.
Sent from my Pixel XL using Tapatalk
red94chev
Northeastern MD
No problem I originally thought I may need lights where the garage doors go up but I don't think it's necessary for what I'm doing. Most of my work area is the back of the garage.
beldar
OK
Yeah, that's an issue I have now. I didn't consider where door would cover the lights.
This time I'm probably going to "frame" around them like you did to maximize coverage with doors open. I may put just one light where door will be in up position, but I don't do much car work with doors closed.
