TurboEuro88
(Crosspost from a comment made in my garage thread)
Been playing around with lighting layouts over on visual-3d.com to get a sense of how many fixtures I should order. Based on wanting around 100FC @ a 3ft workplane, it's been telling me I need 12-13 fixtures but the layout it wants to use doesn't really work with how I'd like to configure the lights. Yes, its a 2-car garage but if I am actually working on or detailing either car only 1 is going to be in there. It would make most sense then that I'd have the lights in a U-shape to make sure I had a light fixture above/behind me. The problem I run into there is that it drops me to ~80FC @ 3ft workplane. Thoughts? Keep in mind the layout of the garage itself, which will have a workbench at the far end, but I'll have under cabinet lighting giving the workbench its own work lighting. It should also be mentioned that the light fixtures I'll be ordering have a higher lumen output than what I could find on visual-3d.com (5200lm vs 4600 on visual-3d), so I imagine that will help mitigate things. I am also basing all this on the garage floor being epoxy coated in a light gray which should help in reflectance as well.
Base Layout @100FC:
Revised 2-row Layout:
Ideal U-shaped Layout:
Base Layout @100FC:
