I'm getting close to needing to purchase some lights for the garage. The main section is 20ft wide by 24ft deep. The ceilings are 11-13ft on scissor trusses. I plan to perform detail work in this area, and I'm getting old, so the more light the better. I have ran a few of my feeder wires for 3 different type of light circuits. The three circuits are:
Overhead fluorescents: When there on, they are all on. "Alot of light"
Wall lights: mounted around the room on the wall controlled by a separate switch
Recessed lights: Enough light to walk in and get something, or when detail lighting is not really needed.
As far as the wall mounted lights I was planning on using these:
http://www.homedepot.com/h_d1/N-5yc...splay?langId=-1&storeId=10051&catalogId=10053
The bulbs are protected if some how they get bumped by anything.
Now for the overhead lights I was looking into these:
http://www.homedepot.com/Lighting-F...splay?langId=-1&storeId=10051&catalogId=10053
They look like a nice setup for the money.
I really like these, but they are really expensive:
As far as the recessed light go I will pick something that is ic contact rated. I"m thinking I will only need around 4.
Does anybody have any experience with any of these fixtures? With scissor trusses I'm thinking about running the fluorescent fixtures from left to right instead of front to rear. I would pair one 4ft fixture with two 8ft fixture that would be 20ft "one row". I'm thinking of a total of 4 rows, two on each side of the gable. Is this too much? How many overhead fluorescents would you think I would need for this space? Also I have read that some fluorescent fixtures cause problems with radios.
As far as installation goes, there is no drywall ceiling installed yet. I'm thinking I will go ahead and install the lights where I want them, then run the electrical. I then would have to take them down before the drywall guys show up. This will also help me get my recessed lights in the correct locations between my fluorescent fixtures.
Thanks for any input. Russ
