Lincoln Floor Jack Servicing
dillonbfox
Hello all, I have an old Lincoln 96042 2 ton floor jack that stopped working. No leaks that I can see. There are 2 plugs under the handle, I opened both and they both seem to be full. Never worked on a jack before and every video or forum post ive seen has just 1 plug. Thank you in advance for any help
paulsomlo
Northern Colorado
The leak is most likely internal, either the pump seal or the ram seal. That's a common jack, should be lots of videos on Youtube and probably a rebuild thread here on GJ. When you're ready for seals, Hydraulic Parts Supply in Sawyer KS, (620) 594-2247.
Stick-man
Mid-South Tennessee
Thank you. I have a Lincoln 3 ton floor jack that is around 30 years old, spent many years stored outdoors in gravel, and still works great! I can't tell you how many times I had to lube the wheels with WD-40 to get them to spin again. Now it lives a good life in a heated shop. LOL
banditbigdog
Southeast
Rebuild thread:
