The Ratchet Man
I bought one of the Lincoln Pro Mig 180 welders that was listed in the Hot Deals section a little while back and have a couple of questions. I've done my fair share of stick welding but Mig welding is totally new to me.
This welder came with the hose for a shielding gas or it can be run with flux core wire. Which method would be preferred at my house and why? What type of shielding gas is preferred? I have access to a local AirGas, and can get a discount through work, so access is not an issue. If it matters, I will be welding up to 1/2" material, which is the recommended limit for the welder.
I currently dont have any 220V in the garage. From the main panel to the garage wall is 85', which includes going up the main panel wall and down the garage wall. The welder input is 20A. What gauge wire would I need for an 85' run to be rated at 30A, to give me a little wiggle room? Will I need 3 or 4 conductor wire? I do little to no house wiring so I'll have this done by someone else. Just trying to get all the supplies together.
