L5wolvesf
I want to get a welder so I can teach myself to weld. I would probably just be doing small tasks with it. There is a Linde 230 welder available for under $100.
I believe this is an arc welder but not sure – can someone here verify that?
Also, I presume it is a 220 volt welder. My question on that – is a welder’s 220 plug usually the same as a clothes dryer outlet?
The seller says it works but may need a fan. I would just figure on replacing it. I did a bit of looking and it seems like if a Linde fan isn’t available there are other fans that probably would work. Is this correct?
Is this a good welder for someone new to welding?
