kap
I have a 16' x 32' barn/shed where I store my convertible in the winter. This is also my car workshop/shed. We have an attached 2 car garage where we actually park two cars. All my automotive tools and mid-rise lift are in the barn/shed as well.
A couple of years ago, I installed a Fahrenheat FUH 5000w electric heater (almost identical to a Dayton unit I had in my previous barn). I currently have a basic Honeywell line voltage thermostat connected to this heater. I set it to 40 degrees all winter. If I go out there to work in the cold weather, I raise the temp to 60 - 65 and it's comfortable. It takes a bit of time to get to temp, so I sometimes supplement the warm up time with a radiant propane heater. Once up to temp, the Farenheat unit works fine.
So here is the question: does anybody know of a WiFi Line Voltage thermostat (240v) that will handle 5000 watts? The highest amperage unit I've found is rated for 16 amps (240v x 16a = 3840 watts). I'd like to be able to turn up the heat from the house before I go out there, and be able to turn it down from the house (my iPhone) when I forget to turn it down when I leave the barn.
