Mr_fixit
Anyone ever repair a linear actuator?. I have one that I broke. I have an idea to fix it, but I'm looking for advice. Especially if anyone ever repaired one .
The motor works fine . It appears that the nut thingie on the ball rod thingie is stripped or broken. I think I might be able to fix it?
I took the larger tube off that covers the hydraulic cylinder looking thing that has the screw inside. Inside I found a smaller tube and a screw that looks like a jack screw of most small car jacks, but the diameter was larger than a car or van screw . AT one end of the tube had 2 crimps. Between these crimps I'm guessing that there must be some nut type thing that rides along the screw. The hydraulic cylinder looking shaft slides up and down the screw, and it not supposed to. Is there a shear pin maybe? a nut that's broke? The cylinder won't slide apart from the screw.
If I could get one of these nuts, which I think must be between the crimps, I'd cut between the crimps, replace the nut thing and weld the thing back together.
Does anyone know what I'm trying to say and how these things work at this level? Thanks.
