I've never really cared for slip joint pliers, I don't know what it is about them. I'll always find a way to use another tool in it's place, be it channel locks or linesman pliers.
So if I own linesman's + Knipex Cobras + Long nosed can you think of a situation where slip joint would be needed?
I know I am the oddball on this forum for not wanting to own 3 versions of every tool.. Just trying to keep things simple.![]()
...Slip joint pliers are one of those tools that almost all of us own because at some point they came with a set of pliers or what not.....
I think Outlaws point.about application sums it up.
If it were me.....and I was up in the air bonding the strand to a piece of #6....it's gonna be linemans. If I was speccing double lashing wire.....it would be linemans that I would be slapping the slack out of the midspan.
If it was an access situation where the linemans pliers would not fit (pulling something) it would be large needlenose.....for me I find slip joint pliers unnecesary.
That said....SO talon pliers are on my wish list.
Talking about linesman pliers and slip joint pliers reminded me of these pliers - the Wilde G264P.
They're the only 10 inch slip joint pliers on the market with linesman plier shaped handles.
Let me tell you, these pliers are absolutely AWESOME.
Telco lineman?
I use diagonal cutters far more than anything else, and I WOULD be grabbing regular slip joint over lineman pliers if I didn't have a dedicated ratchet and socket for every size I need while im in the air working. the only thing I really use lineman pliers for is to grab & tighten our heavy duty tie wraps OR use the cutters only because they are already in my hand.. the only advantage (for me) of using them is they make a good combination tool (pliers/cutters/hitting tool), but I will hardly grab them over other tools, which is funny because I am a lineman.. IMO - they are far better suited for pulling something, or using them like a hammer over trying to turn a nut loose.
that said - I don't own either of the new style like Irwin of Knipex that have a different jaw, designed to address its short comings by allowing you to actually grab hold of a nut and turn it.. there is absolutely nothing the lineman pliers allow me to do over regular pliers and cutters.. unless you want it to pull fishtape, I don't see it as a necessary item.
Rick, I never quite got KC's logic at all. Who would chose to use pliers of any sort for nuts unless there was no other choice? An adjustable is better for that, and adjustable are terrible for nuts and bolts...
For wiring houses, Lineman's are about all I use. except strippers and wireformers.
while diagonals will cut Romex, Linemans make it easier. (Longer handles and cutter close to the pivot point) I use the jaws to twist wires together before applying a wire nut (or for deconstructing old twisted wires) for pulling wire sometimes.
The strippers are obvious as to terminate to a receptical or switch, you have to strip. and the wire forming pliers simply make it easy to get the striped wire into a ring that fits under a contact screw.
YMMV...
Other than combining 2 tools into one is there any real reason to own Linesman pliers over a combination of slip joint and diagonal cutters for the average non-electrician?![]()
The only thing I didn't see brought up was the difference in material cutting between the dykes and linemans. Dikes are meant for cutting soft drawn copper and such. The linesman edge will do that but is very limited in size, but the steel and edge was designed for cutting steel such as small bolts, fish tapes...etc. if you really pay attention to a set of **** specs, different units for different tasks. As for slip joints....baaahh, screw those things. That's something you carry in your bicycle tool kit
Maybe I should add I'm talking Klein. No one else makes a better linemans plier as far as I'm concerned.
What kind of copper do you find difficult to cut with your linesmans? My klein linesmans cut every kind of metal just the same as my klein dikes do, just requires less effort.
The dikes are better at cutting very fine ropes and strings, and the linesman are better at cutting the yellow poly rope.
