Picked this up yesterday.
very cool tool..... can't wait to try it.
anyone have experience with these?
blades are sharp as heck.
They are designed to trim a miter cut, not make a cut from square stock. The closer you can get to your finished size the better, then just slice a very small sliver off the stock.
They are designed to trim a miter cut, not make a cut from square stock. The closer you can get to your finished size the better, then just slice a very small sliver off the stock. They are really designed for inside corners, like a picture frame, most of the time an outside corner will not wok.
The instructions that came with mine showed how to cut angles from 0 to 90. It had pictures of a 90 degree cut.
knowing where you're located might help. I can't imagine this being inexpensive to ship.
I don't have time to read the entire thread. Is this for trimming a lion's claws or it's mane? How do you get a lion to hold still for a trimming?
