I bought Hubell Raco brand metal Liquidtite fittings. They come with a yellow split ring washer/gasket that goes around the conduit. There is also a yellow flat washer between the body of the fitting and the lock ring. My guess is that this is a waterproof seal that is meant to go between the fitting and j box and the lock ring then bites down directly on the j box. Is this correct?
Should I install a redhead sleeve on the inside of the fitting on the j box side?
Thanks
Thanks
