pgray007
I'm installing a new humidifier in the attic. Current dead one runs (a Honeywell TrueSteam that I'd like to take out back and shoot if you're wondering) off a regular old 120V plug, and the new one is 20A/240V.
I'm running new service, and I'll put a service disconnect near the humidifier, and when doing this outside for HVAC electrical have generally used Liquid Tite. I don't find Liquid Tite the easiest stuff to work with, it always wants to go left when I want it to go right. Is there a better alternative, other than PVC or metal conduit for this application? I'm wondering why you couldn't just put an appropriately rated 240V outlet with a switch and wire a plug to the humidifier since we're indoors, although the HVAC tech that did the install system install used Liquid Tite from the service disconnect to the furnace so I might be missing a code/best practice.
Or, should I whack the Liquid Tite with a heat gun a bit to make it more pliable, or is there some other voodoo that I'm not aware of? Or finally, do I need to just take Arnold's advice and stop being a girly man and just muscle it around...
