Lisle tools: Pickle fork kit?
86k10
Colorado
I am on my second set now. The first one lasted about 6 years of good use. I lent it out to a co-worker and he brought it back with the threads destroyed. The second set is a stepped set and is hanging in there. Cheaper than buying 3 different fixed forks.
ihateminimumwage
Mine has been working great for a couple of years now. I've used it solely with my long air hammer, and has been great! Worth every penny.
signcrafter
I've never used the step design before but I have the same kit non-stepped that I bought about 10 years ago and it works great. I could see the step design coming in handy. I don't use my kit much anymore since I bought a few different ball joint and tie rod pullers. Work better without damaging the boots. But if I'm replacing the part and it's being stubborn I'll get the lisle kit out with the air hammer.
NC-Fordguy
I keep that set in my Bronco for trail repairs. I've had it for I dunno, 10 -12 years perhaps. It doesn't get used a whole lot but works well when needed
Requin6
Frederick, MD
I have the non stepped kit and it has been great. I only use it sparingly over the 15 years I have owned it but it has done the job every time.
kossuth
Thinking of picking up this kit, anyone got experience with this set?
http://www.lislecorp.com/divisions/products/?product=505&division=1&category=2
In all honesty, if you are doing frontend work where you don't want to destroy the boot or the balljoint/tierod end like getting to the struts on a newer dodge ram then you need one of these kits http://m.grainger.com/mobile/details/?R=2HLG3 or something similar. I have one to do my own repairs here at the house and it has worked 99% of the time. Rarely do I need the old pickle forks anymore
I
ianguilly
Cincinnati
I do some light suspension work, and i'm not concerned with saving the boots since most of the time they are being replaced. Thanks for the input guys.
Mustangmike
Scarborough,Ontario
I work in a truck shop. I have a MAC branded set that is identical to this one. It works very well for me everyday to split ball joints/knuckles, tie rods and steering shafts. Like prev said , it works very well with an air hammer or a BFH
lilscorpion
Colorado
I also have the non stepped kit. No issues but I make sure the forked are fully threaded in as I use them. I've had a few different fork kits over time and this one has been the best so far.
Gabastone
When I first got it, I was worried that I would be hammering against the threads, but that isn't the case. The threads are loose and it catches the back.
It is great, and I would buy it again.
Coach James
Sandhills of North Carolina
This looks like the same kit for less $$$$.
http://www.amazon.com/dp/B000TDCCHW/?tag=atomicindus08-20
Coach
