Little Fiver Hydraulic Press
Ga41chevy
74B01BBF-E86F-4135-BD3F-19604EF5A384.jpegI recently purchased a 5 ton press; hence the name Little Fiver press. Compared to my real press it’s nothing, however bought it for display and occasionally I would like to use it to keep it operational. It’s about like a coke can crusher. It has a job, it can do the job, it’s a simple design, and I can quickly dismantle it too move to a different location.
My problem is I have spent hours on the net trying to find information on it and have been unsuccessful. I believe it was probably made in late 30’s to mid 40’s but just guessing. Hoping it would work when I got it to my shop, I added what seemed like a quart of hydraulic jack oil. (10wt was on decal) I pumped and got movement. I opened the open/close vale to let it retract. After numerous cycles I can get it to extend to 75% but it will eventually retract on its on without opening the valve. I’ve attempted to pressurize it with it pushing against a solid piece of shaft and it will not get under any load. I’m thinking it probably has all leather seals in it because of it’s age. I’m not a hydraulic person and I don’t want to take it apart and it end up in a bucket with me asking for help on something that I took apart. I’m attaching pics so hopefully you brilliant minded people can help this confused minded person. Thank
B_Bimmer
Eastern Iowa
I would be unable to resist something that cool if it was local to me. However I can offer nothing helpful to your questions.
If you are really desperate, apparently there is a catalog in the Denver public library
Looks like they were still in biz in 1966
He may have had a patent in 1935
Ddi some aircraft work in WWII
Middle name John in a 1948 publication
From here you could probably dig into a little more depth, but seeing nothing on his products.
G
Ga41chevy
I can move this to the Vintage Tool thread if you'd like? My searching didn't turn up anything either.
Sure. It’s my first forum experience and I didn’t know where to post it originally. I know there has to be Hydraulic guys out there with great info to get this thing operational.
Fierljeppen
Very interesting hydraulic press!
I did a search on Google Books and found a snippet from a 1949 Modern Machine Shop magazine. Then I headed over to the Archive.org site, found the magazine and downloaded the page, which is below.
1949-07_modern_machine_shop_pg.226a.jpg 1949-07_modern_machine_shop_pg.226.jpg
This was the only information that came up in my search.
As far as getting it to be a functioning press again, you could hookup with a local hydraulic shop and work with them for the knowledge and parts that will be necessary. I've used a couple in my area for similar needs and both companies were able and willing to help me.
Cool piece of history, update the thread as you make progress.
G
Ga41chevy
Wow I’m impressed! I have spent several hours trying to get info. and I came up with nothing. You did good. I will try the local shops and see what they can do. Thanks for your help.
Roberts210
Missouri
Take the upper assembly with the hydraulic cylinder to a hydraulic jack shop. They will be able to rebuilt the hydraulics, and then you can spiff up the rest of it.
KZRider
Nebraska
I bought the same model press at an auction and am attaching a couple of pics. Included is a Dec, 1968, invoice for some parts for the unit that was in a box that came with it. Did you ever get the jack operational? Just curious as mine is also needing work.Little Fiver Press.jpgAJ Hurt Invoice(1).jpg
G
Ga41chevy
Hey thanks, glad to see another press like mine. Ive got a hydraulic guy who has ran his own business for forty years working on it. He says he should be able to update all the seals to modern types. I want it functional but I have a large press for my daily work. I will get him to give me a parts list and brief notes on what he had to do. I hope to get it back this week, however, he’s been taking cancer treatments and his next one is the 10th. So I might not get it back this week. I will give you the info he gives me if you are interested.
  • Like
Reactions: RTM
KZRider
Nebraska
Thanks! I would love to hear how that goes. In no hurry. Any info on the repair would be welcome. Nearest hydraulic repair shop is about 80 miles away so I think I will attempt the job myself if possible.
KZRider
Nebraska
Ga41chevy, I see that your serial number is 1140. Mine is 813 which I presume makes it but with no idea how many a year they were making. It is very tempting to just remove the bottle jack portion of the press and retrofit a new jack in its place. It is my hope to actually use this press for installing or removing bearings and the like. Nothing heavy duty.
