I recently purchased a 60 gallon air compressor that I intend to put in a tool shed. The tag on the compressor says it is 240 volts, 15 amps, and phase 1. So, long story short. I need to run power out to my shed from my main breaker box. I want to put a breaker box in the shed. The shortest distance to my shed from the house is 75 feet. What size breaker should I use to run the power out to the shed? What size wire? And what size breaker should I use to power the compressor? If no-one has an actual answer, a website suggestion would help.
