dcg9381
So substantial power outage today and I needed to power up the shop via generator. Have the interlock kit in, tested, everything wired up. Good to go? Sure. Nope. I didn't test the whole deal.
I'm using the following generator inlet box.
The generator cord is 50-Amp Generator Extension Cord, 125/250V, Inline NEMA 14-50P to SS2-50R Twist Lock Connector. Only this thing won't "fit" in the inlet box, goes in about 1/4, won't twist. It also lacks the "threaded collar". I don't see any other way to allign it and keep the ground-ground contact.
There is a center guide pin on this, which looks OK, but I did pull it out, no change on seating... That seems to be the "cord" side difference between CS63564 and SS2-50R.
I see a designation that CS6375 as a 50A 125/250V flanged inlet, while listings for CS6364/SS2-50R describe it as the matching female locking connector.
Trying to figure out what I did wrong before I throw another $100 at a 50A generator cord...
