DeerePower
- Joined
- Dec 22, 2014
- Messages
- 2
Hi All,
Recently put up a 40x56 pole barn in Iowa. Currently working on getting power to the shop sub-feed from house with 100 amp service. I've completed the trenching and have a 2" conduit entering the building from below grade. I have added 2x6" girts on the inside of the post (similar to the girts on the outside of the post to which the steel is fastened) which i plan to hang a large 3/4" peice of plywood to mount the load center. I went this way in case i plan to insulate in the future. My question, what is the cleanest way to route wiring from the load center to lights, outlets, etc? Simply come off the plywood and run behind the post on top of girts or up the side of posts to light fixtures? Any pics of your setup would be appreciated.
