scott750
I've been searching around local businesses to professionally epoxy my floor and I found this one place that was recommended. But looking through their FAQ's they state:
So they don't Diamond Grind the floor during prep, only acid wash 2x. I haven't called them yet to confirm, but should I write off a business simply because they don't Diamond grind during prep? Reading here on the forums it seems that Diamond grinding the floor is a pretty crucial step.
My House was built in April 2011, there are only maybe a couple oil spots when I laid down the gas weed-whacker and it leaked, and the floor surface is rough but always has white powder on the surface.
So I'm not sure if my garage floor requires diamond grinding since its so new and has a rough surface already. It's not shiny or smooth at all.
Q) How is the garage floor prepped prior to putting down the epoxy?
A. Preparing the concrete is the most important step in the installation process. We will first remove all oil stains from the floor using degreasing products. Any minor cracks in the concrete will be repaired. Finally, we almost always use chemical etching to prep our floors. We have used grinders and shotblasters in the past. However, we quickly learned this type of equipment is just too aggressive and invasive for residential garage floors. They can crack concrete and break off chips of concrete. In the end, they just create a lot of dust that settles all over...such as your work bench and dry storage areas. In order to ensure our acid etching creates acceptable levels of "roughness" so that our epoxy adheres forever, we simply do it TWO times. This works every single time and we have had no trouble whatsoever.
