Locate Pipe Underground
Wamsutta
Amarillo, Texas
What's the best way to locate a clay pipe 5 feet under the ground? Is there a way to do it without paying a plumber several hundred dollars to use his sonar thing? The last time the plumber did that, he didn't even know exactly where the pipe was; he just gave me a general idea. I know it's 5 feet underground because if I stick my tape measure into the clean-out T, the tape measure says 5 feet when it hits the bottom of the T. Right now is the perfect time of year to be digging. The soil is nice a soft from all the rain and moisture.
bigfunwmu
S. MN
Know a couple kids who are getting shovels for Christmas?
Having been one of those kids, it seems to get the job done...
djbmw
Ottawa, Ontario, Canada
Really the only non-destrictive way is with a locator. There are many types of locators with varying accuracy, depth capabilities, and cost.
Personally, i would use a Radio Detection Locator and send a becon into the pipe for the locator to pick up on. My locator has extremely good accuracy and, at 5' of depth, I can tell you EXACTLY where the tile is, to a 1/8".
There are consumer grade detectors that you can buy on amazon and vevor... but i cant vouch for them.
Ing3018
Michigan, USA
You can purchase a locator kit with a sensor and transmitter. You fish the transmitter down the pipe and trace the pipe's location on the ground above. Here's an example, though I know nothing about this specific unit: Pipe Locator
PCustoms
VT
You know the clean out location?
Which end are you trying to find?
W
Wamsutta
Amarillo, Texas
I'm trying to find both ends. The clean out location is about part way between the house and the street. The plumber has to go both directions with the cable auger when he comes to clean out the pipe; one direction towards the house, and the other direction towards the street. Getting that cable auger to make the bend and the bottom of the T is a skill all to itself.
PCustoms
VT
Wouldn't one end be inside the house, and the other end in the sewer?
I'd think the plumber would only be able to access the "start" of the pipe in the house, and then again at the clean out.
Toold_up
Attached
Sometimes the pipes have bends between point A and point B
nadogail
Coronado, CA
I used Cable Pipe and Leak detection with their Ground Penetrating Radar.
A good Metal Detector will find a buried Fish Tape.
no704
Pretty sure you can rent the camera snakes that have a hand held locator. I paid a plumber $250 to run one down my main sewer.
Toold_up
Attached
Why are you trying to locate the line? Are you replacing the terracotta with PVC?
What's the holdup? Mini excavator time!
W
Wamsutta
Amarillo, Texas
One end of the pipe starts between the two bathrooms I'm assuming. The bathrooms are on the street side of the house. The other end of the clay pipe is under the city sidewalk next to the street somewhere. The clean out was originally by the front of the house I would imagine. A section of the clay pipe was cut out where the tree destroyed it. A section of 4 inch ABS was installed using those rubber sleeves with the giant worm clamps. The clean out was moved to that ABS section in the form of a 4 inch Tee. I sure wish I had a plumbing blueprint from when the house was built.
American Locomotive
Rhode Island
Check Google Maps satellite view or the Bing Maps "birds eye" view. You may be able to see a line in the vegetation that traces the path of the pipe, especially if you know where the cleanout is. Grass, weeds, etc.. will grow noticeably different above buried pipes, even decades later. Either due to heat, moisture, or the disturbed soil being a different composition than the surrounding soil.
Also, if you can see to the bottom of the cleanout, just look at what direction the ends of the tee are pointed. Generally sewer connections are made as straight as possible.
Another thing to keep in mind, you don't need to know "exactly" where the pipe is. The whole you dig is probably going to be a few feet wide anyways if you're going 5 feet down.
W
Wamsutta
Amarillo, Texas
That terracota needs to come out. The tree has taken ownership of the terracotta sewer pipe. The tree has also taken owership of something underneath the city sidewalk. About a 15 foot section of city sidewalk is completely lifted off the ground. You can easily see the bottom of the sidewalk. Tree roots run the whole length under the sidewalk. Looks like anaconda snakes supporting the sidewalk.
A mini excavator would be perfect if the tree wasn't there. The tree has roots going everywhere that are about 20 inches in circumference. The trunk is 80 inches in circumference. Ginormous ash tree with a constant supply of city water coming from somewhere.
PCustoms
VT
I don't get the need to locate if it's being replaced.
Start digging at a known point and go from there, laying PVC as you go
W
Wamsutta
Amarillo, Texas
What I'll probably have to do is intersect the clean out Tee with a trench coming in perpendicular to the clean out Tee. That's the only section of sewer pipe I have located. The water line already has a trench dug above it. I think the sewer pipe and the water line are in the same trench but with the sewer pipe way deeper than the water line.
dscheidt
There are people who specialize in replacing sewer pipes in place, using an expanding liner that bursts the exsiting clay pipe. Works pretty well, little or no digging involved (the ends sometimes require hands on work, so need a hole in the street, maybe.)
Toold_up
Attached
You are over thinking this.
You know the trench is 5' down. Dig 4' then very carefully remove a few inches checking for P stone or the water line that you do not want to destroy. Pipes should be bedded in small stone to protect them. Once you hit stone it's time to go slow.
As long as there are no electric or gas lines this is an easy job. Oh and don't go into a trench that is 5' deep without a trench box. If there is a cave in the pressure from the dirt will cause the blood to rush up your body and can pop you like a water balloon, or compress your diaphragm and suffocate you. OSHA standards and stuff...
Toold_up
Attached
I've done burst jobs before, that is cool stuff. I love the sound as the cracker goes down the line. It looks like a giant broadhead that they pull through the pipe from one end to the other with a wire rope. The pipe is one continuous flexible line that is fusion welded to totally seal it. Expensive, but cheaper than cutting up a newly poured driveway or pool.
ER70S-2
In my area, the utility companies have a service called MISS DIG. Call them and they will come out and identify any underground lines. They then mark them with different colored flags.
Same here, but they usually don't mark on private property or have fancy equipment like GPR.
