slackdaddy1
I completed moving my IR T30 vert 60 gal 5HP compressor to the shed.
I plumbed in an after cooler between the cylinder out put and the tank (Check valve)
I capped off the output bung and fired it up and let it build to 80 psi, then cut it off.
In 24 hours it has leaked down to 45 psi.
There is nothing hooked up to the compressor, the output bung (on the right side) is plugged with a MNPT plug and sealant.
There is a bottom drain with ball valve.
On the left are 2 bungs:
One with a tee- the pressure switch and a safety relief valve.
2nd has the checkvalve with the compressor in (including the relief/bleed off line from the switch.
I used soapy water leak detector and found nothing on any of the tank fittings and connections,,
The only things that could not be checked was the diaphragm in the switch,, or the check valve could be leaking back to the cylinder?
(this is probably a 20-25 year old compressor with original stuff.
Thoughts on finding this phantom leak ??
