There are at least two vendors of IR camera attachments for your phone, Seek and Flir.
I bought the Seek, but the Flir gives a better image, probably because I picked the wrong model Seek, ie the LR model (long Range) instead of the standard model.
The Seek I have works, to a point, but my lift is straddling the tubes in a couple of places, so I won’t finish drilling the holes until the heating season is done.
Tip: put icicles or ice cubes in the baseplate holes while looking through the IR camera viewing screen. The holes then show up as intense blue cold points that contrasts with the warm red tubes.
My tubes are anchored to the foam insulation at the bottom of a six inch slab, so I should be ok, as long as they didn’t float during the pour, but i’ll Wait another 8 weeks until spring arrives to do the drilling.
One thing did happen during this adventure though. I initially had difficulty finding the tubes in the 24x34x16’ addition the lift will be located in, while the tubes in the main 32x48x16’ addition were relatively easy to locate with the camera. Ends up that the Taco circulator pimp for the lift area had a fried circuit board, and the lift room was only being heated by parasitic flow, since there were no check valves to isolate it.
New Taco pump, and I can see the tubes in the area of the lift.
