I searched around and looked at the online manuals, most people seem to be placing their NG heaters in the foremost corner and directing the heater towards garage doors.
I'm wondering if I can place mine in the upper-left corner of the garage (A), or if that will negatively affect the space. Below is the layout of my 3-car garage. In the picture of a house, the white line would indicate where I normally see heaters mounted (B). As you can see, a vent coming out of the roof in that front corner of the house would look well, less than stellar. My concern would be that under normal operation, two cars would be next to the heater (A) in the 2-car garage. Would having the heater that close be dangerous or cause blockage of air flow? Am I better to just leave it in the bottom-right corner (B) and deal with the poor aesthetics on the front of the house?
Garage ceiling will be over 11' (flat), the cathedral will probably finish at 16' to the peak.
The option of running it to corner (A) would allow the vent to be blocked by the large roof line. Yes, it will obviously be visible from the garage door side of the house, but would not disrupt the "front facing" view of the house, if that makes sense. Horizontal vent is out, as it would stick out the side of the house near the porch. Also keep in mind that I'm 99% convinced it will be a sealed combustion, so two vents are likely.
[/url]
