LockNLube Grease Gun Coupler
karoc
Hemphill Tx
Do these actually work? I sure have hard time getting off/on grease fittings
scooby074
Nova Scotia
Yes they work great. Only issue is deep or shrouded zerks, its a bit fatter than a normal coupler
JeepYJ
Yes the LnL works. A regular grease hose can be loosened or tightened on the zerk by turning the end of the hose fitting.
Snapped-off
Indiana
They work really well, obviously some spots you may have trouble getting to with the extra bulk. But changing out the zerk for different angle can sometimes solve that issue.
toyotadriver
Love mine. Have one of their grease guns too and I like it as well.
Nothing in this post should be misunderstood, interpreted, misinterpreted, or construed to be of a political nature.
2ndGearRubber
Pittsburgh
It's works okay. It can get clogged with junk easier than a normal nozzle. The additional bulk means driveshaft joints can be impossible, as well as lower profile zerks.
Mgdoug3
KY
I have the regular length one and the long one. Long one works fine on u-joints on my truck and farm equipment. I bought the long one several years ago (~5 years) and just rebuilt it this past fall. Extremely handy on an electric grease gun and don't waste as much grease.
ronkz650
Denver, CO
Mine works great as well. For zerks that it's too long to reach, you can buy the 90 degree adapter, but it's kind of iffy in performance.
LopezBart
Lopez Island, WA
I've had some trouble greasing our JD 110 tlb; some of the zerks are pretty shrouded. I'll need to give it another chance after I've cleaned and inspected it; I had issues w/ it leaking.
danielbuck
I think with any grease gun, it helps to clean them off before putting the grease gun to them, even if it's just a paper towel and wiping off most of the crud. That's also a way to keep less dirt getting forced through the zerk into the joint.
LockNLube / LockNLube, 24 Interchange Dr., West Lebanon, NH 03784 / https://locknlube.com/ / est. Dec 2013 / grease gun and air couplers and accessories / https://www.garagejournal.com/forum/threads/lock-lube.525932/ / https://www.garagejournal.com/forum/threads/locknlube-hot-deals.525052/ /
There are a couple videos linked in the LockNLube "Hot Deals" thread.
If my memory serves me correctly, they've got some sort of promo running currently... not sure.... hopefully they'll weigh in here in the morning. ;)
Jswain
Calgary, AB
It's nice to have around but I wouldn't use it as my only grease gun. They don't fit in a LOT of areas because not only are they thick & bulky bit 2-3 times as long as a regular end.
They are great for having around on an electric gun for hard to grease zerks that need more pressure and saves you from having to use a zerk cleaner.
Muckin_Slusher
Abitibi
They are awesome and worth every penny.
Obviously they won't fit everywhere, but still worth it.
To avoid having two grease guns, you can make an adapter with a length of hose fed by a grease ****** and has a regular coupler on the end. Clip it in your lock-n-lube and you're back to a regular coupler.
rlitman
Long Island
...To avoid having two grease guns, you can make an adapter with a length of hose fed by a grease ****** and has a regular coupler on the end. Clip it in your lock-n-lube and you're back to a regular coupler.
I have a needle and rubber tip adapter each with a zerk in the back like this. No hose. Grease hoses are surprisingly dangerous if you hold it under pressure, and with the needle and cone tips you need to be holding them to use them, so no hoses on those for me, but otherwise it's a great idea.
