Lockable power options for lift
Huntmaster86
upstate NY
Good morning. Looking for options to lock the power off on my 2 post bendpak lift. My garage is popular amongst my friends and I don’t want the lift used when I’m not home. Anyone have any options or ideas?
Norcal
A safety switch, or a breaker locking attachment on the circuit breaker supplying the lift, which will be the cheaper of the 2 options.
mike93lx
Richmond, VA
If your friends can't respect your wishes, they shouldn't be in the garage unsupervised anyway.
But as suggested, a lockable disconnect would be a cheap solution
nadogail
Coronado, CA
Either a key switch or a lockable disconnect. This will allow you to limit the use to "Qualified Operators" both a Safety and a Liability concern.
dave*99
Coastal NJ
There is usually a 2 wire normally closed circuit connected to the safety bar. The bar that stops the lift when the car roof gets to the top of the lift.
It would be easy to wire a key switch in series with that limit switch. This will stop the lift motor.
That’s likely less work than a new disconnect.
Jking24
My friends use my stuff at will. All the tools too.
As do my freinds and A. if their not trustworthy their not my freinds and B. If their not qualified to use somthing as basic as a lift their not gonna be in my garage when I'm not home
pbon
Those seem like good rules. Usually my friends and family want me to help. It’s not an overwhelming amount but I’d be happy if they could just come over and DIY.
matt_i
I've used similar to these on a few pieces of equipment to keep unauthorized users at bay. Simple keyed switch, easy enough to wire up with your lifts power.
https://www.homedepot.com/p/Leviton...le-Pole-Key-Locking-Switch-1221-2KL/301447090
V/R
Bogie
Wow an $86 switch! :shocking:
That would be cool for the unique factor though.
However, it doesn't disconnect the incoming power for troubleshooting though which is one of the intents of a "lockout point". I realize the O.P. is trying to secure it and not up his personal electrical safe work practice game.
slow
near Orlando
I second the disconnect. I have seen the buttons get stuck on a lift before, and the emergency cutoff turn them off after the hood has already made contact with the ceiling. Many lifts don't need one as they are in line of sight of the panel, but not everybody knows where the correct breaker is.
59 wagon man
hollywood fla
just park a car over the lift lock the doors and take the keys or put them in the house .0$ cost . otherwise you will hear" well I didn't think you meant me"
mike93lx
Richmond, VA
Thanks for the responses. My friends use all my tools when ever they want but seeing their all younger and less responsible/ experienced I don’t want anyone thinking they know what their doing and getting hurt
I get not wanting people to use the lift, but if they can't listen to your request, you are in for trouble on other stuff. Good luck either way
lakeroadster
Central Colorado
I installed a lockable kill switch on my Rotary lift. If you lift the STOP paddle you can insert a lock that disables the START switch.
The other big advantage of this switch is the momentary switch that is supplied with most lifts have been known to sometimes fail... in the on position. This set-up allows you to cut the power to the lift quickly and directly while operating the lift.
Links provided below for the enclosure and switch.
https://www.amazon.com/dp/B005T78D8K/?tag=atomicindus08-20
https://www.amazon.com/dp/B005W17FRS/?tag=atomicindus08-20
dave*99
Coastal NJ
Page 64 of this schematic shows a contactor that will not be carrying full current:
https://www.bendpak.com/GP-7-Series-Two-Post-Lift-Manual-5900209-BendPak.pdf
EDIT: dunno if that's his model but they're probably all wired similarly.
Interesting. I searched the GJ board and stumbled upon a thread on run away bend pak lifts. It seems something in that control circuitry has been known to stick on.
https://www.garagejournal.com/forum/showthread.php?p=5324404#post5324404
kabinenroller
S.E. Wisconsin USA
I posted on that thread about my Bend Pak switch sticking in the “on” position. It happened again not too long ago, luckily I installed a disconnect box on the lift and relocated the push button on the disconnect box. As soon as the switch stuck I pulled the lever and killed the power. As I mentioned in the post on that thread: I would never purchase another Bend Pak lift. Too many bad design features.
gbigpapa
Kirkland, WA
Hi guys,
I am revisiting this thread as I am also looking for an option to lockout the lift when I am not using it. Mostly to prevent my kids from playing with it or wanting to show off to their friends. I found this industrial double-pole keyed switch but it is only rated for 20 amps.
The bendpak motor says it is rated for 11amps:
Is 20amps sufficient? Bendpak recommends 30amps but are they being overly conservative on their power supply rating?
Thanks,
George
mm08822
Hi guys,
Thanks,
George
That switch is only rated for 2 hp. Your lift is 3hp per your chart.
Switch could have a shorter life. If the switch is opened only when no motors are running it could be fine.
gbigpapa
Kirkland, WA
My garage will be more for display and looking for a clean installation rather than industrial look on the lift.
If the lift really needs 30amps I suppose I could remotely mount a relay to feed the lift 30amps but use a lower amperage keyed switch at the lift location to energize the relay.....
Just trying to find an elegant solution but add some peace of mind with kids in the garage when I am not present.
I've reached out to Bendpak but haven't gotten a response yet.
-George
mikedodge
A disconnect switch that you can lock in the off position would be the simplest pus give you an easy way to stop it in an emergency. A switch like this would work too. Some are more affordable then others.
Or an AC unit disconnect switch you can usually put a lock on the cover to keep people out, they don't look too bad and they're cheap like $20.
