Locking lug nut "Emergency" removal socket ?
Packard V8
Spokane, WA
A friend with an old Porsche 911 has lost his magic OEM locking lug socket. The locks are cylindrical with a special/odd pattern on the bottom next to the tapered seat.
I checked at NAPA and their Ken-Tool socket is $75. It's like a female ez-out, with left hand spiral threads inside it to cam onto the lug nut.
Any other suggestions?
If nothing affordable presents itself, I'll be trying 12-pt metric and inch sockets, trying to find one which is a drive-fit on the cylindrical part of the lock.
jack vines
619DioFan
San Diego , Ca.
I have the set from craftsman ( 3 piece set ) double ended- on end for stripped lug nuts the other for locking lug nuts. works very well.
Bjkearns
I would get on the Porsche forum and see if you could the PROPER socket
Nanashi
In this case use the 12 point hammered on. However for the professional using a twist socket works fast and easy. Plus you make your money back eventually, each lug i take off with one gets replaced with a new lug making me $2 dollars so its not much but tbats $8 a vehical and i saved a tone of time over the other method.
elderstarr
The one and only good use for this thing. Wheel thieves love em
ElectroLight
Rockville, MD
I bought that set from Sears a few years back. I had a wheel lock on an F150 that was stuck good (distroied the key trying to remove it); maybe on there for 6 years. Tried the socket trick, nogo. One second with these basterds and that sucker was off. Good stuff, made in the USA, at least the used to be...
Bjkearns
Some of these suggestions are well best saved for Hondas....
Air chisel and welding near expensive wheels=NO
jjjrmx5
Cincinnati, OH
jack vines
jack, that sounds like the second generation of the OEM lock. The first generation used a lock style flat key that was used to unlock and remove a black cylinder that blocked a socket from being placed on the nut. Remove the sleeve and the wheel nut skinned up for the cylinder buy was the typ. size where it met the wheel .
When the went to the castle/squares and grooves design you need the correct hollow lug "key" that fits."
I suggest you go to the dealer and ask them to remove the 4 offending nuts/bolts (depending upon the year of the Porsche) and then replace them with the standard OEM fastener untill you can suss out which socket key you need (there should be 6 or more variations) .
Hunt that one down via Renlist or any dismantler will have one if you know the key part number.
It's all a matter of cost and finding one to fit, but remember, it's a Porsche. I own one and found out real quick it's a "Pay to play" high perfomance vehicle for a reason.
metalhead212121
to all the previous posters..... good luck doing this with a GERMAN SYTLE KEY LOCK! Most of the responses would work on a american/jap car designs.. NOT German ones. When I was at BMW it was air hammer, chisel, swear and then repeat over and over again. Its a long painful and expensive process....
jjjrmx5
Cincinnati, OH
Will the removal torque on the problem lug be less if the ones on either side of it are wicked tight than if they are already loose or off?
Doubtful.
Factory torque specs for most P-Cars are 96 ft/lbs which tend to be on the high end for a road car. Panamera and Cayenne are 118 ftlbs.
I tell the same "trip to dealer" for my VW friends. Worth the trip in the event of a future flat as well even w/RF's.
Once you get one lug/bolt off, the secutiry lug code should be stamped on the side of the bolt head.
