Locking Pliers/Slide Hammer
redwrench60
East Tennessee
Or just get the vice grip adaptor for slide hammers. It replaces the tension screw in vice grips and fits 5/8 18 thread slide hammers. I use mine often.
RCRGarage
San Diego, CA
I have the one on eBay. Works well, but I use it for bodywork- pulling pinch welds, edges, studs... I needed the pull to be more in line with the jaws. Ended up welding a bolt to the spine of the vise grips. This way, the pull is directly in line with the jaws. Otherwise, you might end up getting funky pulls/bends/creases in sheet metal.
blacK20
5/8"-18? you sure?
i have a lot of Vise Grips and mine are smaller
The 5/8"-18 is the female end of the adapter so that your typical slide hammer can thread onto it. The male end threads into the vise grip.
Larwyn
Texas
I took the easy way out and just welded a nut to the adjusting bolt on the Vise Grips. I always expected to find a need to change it to a configuration that would provide a straight pull but it has always worked just fine the way it is. I have drug my pedestal vise around the shop with it so it seems plenty solid.
redwrench60
East Tennessee
My Vice Grip slide hammer adaptor came with my slide hammer set. When I first got it I thought to myself, what the hell am I going to use that for thats useless. I couldn't have been more wrong. I use it often, it's a life saver!
