Lock’n’Lube Coupler
Captain Spaulding
Southern Indiana
Home at the family farm trying to help get equipment ready. I really miss my coupler. Anybody know of a chain that carries them? Called a couple of local places that the company says are dealers, but no luck finding one.
pat9198
I saw them on the counter display at my local Napa the other day
atthebeach
At The Beach
Maybe I got a lemon, but mine was useless. If you didn't hold it in place, it would just leak. Had to reinstall my old coupler and throw this pos in the trash.
mcbane
California
That unit comes with replacement seals and jaws. Those didn’t work? In any case, if garbage day hasn’t come yet there is a 30 day money back for any reason.
backroad
Arkansas
Not to be a ****, but are you using it correctly? Mine was doing the same thing, and I thought it was a POS too. Then I learned you have to push it up on the zerk pretty good to get the jaws to lock down on it. If you just stick it on there like a normal fitting it will leak all over the place, but if you push a little harder the jaws will collapse over the fitting and hold great.
tarmy
Nor Cal
This...and make sure the outer sleeve slides into place to lock it on...they work great.
rlitman
Long Island
I didn't think you could use it as a push-on. I depress the handle on mine, stick the chuck over the zerk, release the handle, and then pull to see if it is stuck on or not.
