Which of these do you think would be less likely to come loose over time? I drilled out two rivets holding a window regulator track so I could replace the broken plastic sliders with new ones. For reassembly I will use a nut and bolt with Loctitie blue or a nylon lock nut. The door panels on these cars are a pain to take off so I'd like for the bolt not to come loose down the road. Which would you choose to go with?
