Hey all. I've got a 15x30 garage condo unit, and I want to build a 15x12 mezzanine in the back portion of it. Somewhere to park some storage, as well as air compressor, dust collector, that sorts of thing. I'm trying to figure out the best way to construct this so I can have something a little more firm to take to contractors to find somebody to actually do it. (I have to get this permitted and done by a licensed contractor).
It's a garage condo in a much larger steel framed building, so this thing has to be self-supporting. I've seen a few other lofts in the condo complex and construction methods seem to be all over the map so figured I'd start here.
For no larger than it is, and for how gross a lot of lumber I'm seeing lately, I'm kind of inclined to have it built with I-joists and LVL beams. Should be a little more likely to stay flat in unconditioned space as well. I'm kinda inclined to go to 12" joist spacing, as well, because it'll only cost me 3 more joists and I'm even less likely to ever overload it.
Sizing/spacing for joists cross the 15' dimension is straightforward to work out. What I'm not clear on is how to hold those up. Probably 12' LVL's on top of 6x6 posts in the corners. But where I'm really unsure of is what method of bracing the posts to both the beams and the end joists to give the whole structure racking resistance. There just doesn't seem to be a lot of information about building this kind of thing, and building it well.
thanks!
thanks!
