Loft / Mezzanine flooring
gbrett
I am building a 40x60x16 pole barn and plan to add a 12x40 loft. I had planed to floor it with 3/4 T&G OSB subflooring. With how much lumber has gone up recently I'm looking for ways to cut costs. I have the opportunity to get 3/4 plain plywood for about $20 a sheet less that OSB but it won't be T&G. how important is the T&G for a storage space with 16" joist spacing?
BFBOB
Do you have a router? If so, rout a 1/4" slot about 1" deep all around your plywood wherever it meets another piece of ply, and glue in a strip of 1/4" plywood. Instant T&G.
Yes, it's fairly important because some of your joins will be across the joists and unsupported. Splines will greatly reduce the bouncyness when stepping near those unsupported edges.
Today's socalled 1/4" ply is thinner, but a 1/4" slotting cutter is really .250", so use Liquid Nails for subfloors for your glue so it wll fill up the joint and take the slop out.
G
gbrett
I don't have a router not much of a wood worker lol.
strutaeng
Dallas, TX
Just add blocking where the joints don't fall on the framing. I think that's how it was done anyway before the T&G short goods came along.
Good way to use those scraps also.
G
gbrett
That is a good solution, I will need some blocking between joists anyway.
