Loft stairs, inside or out?
wliggett
I am preparing to build a woodworking shop/garage 30x40 with a double garage door on the front gable end. I plan to have a loft with load bearing trusses and am trying to decide whether to place the stairs inside or build a landing with exterior stairs and a rear entry door. I plan to use the loft for a wood drying kiln and storage, so I won't be going up there frequently. I would appreciate pros and cons from anyone with prior experience. Also, any general advice on a new construction workshop. Thanks, Walt
RVDan
North America
Pro for inside stairs: don't have to go outside to go upstairs
Con for inside stairs: stairs eat a lot of floor space
Pro for inside stairs: don't need an exterior door upstairs
Pro for outside stairs: don't have to go inside to go upstairs
Con for outside stairs: weatherproofing, pressure treated lumber etc
I wanted my stairs inside but I didn't want to give up the floorspace
Tbucit
East of Atlanta
I put mine on the inside and if you are going to do the same here are a few thoughts. You can use under the stairs for storage and if you leave one end open you can add a hoist to get stuff up there. There are a few pics in my build
Randall
ForceFed70
BC, Canada
I put my stairs outside and I'm glad I did. It makes the room more versitile (I can put an apartment up there if I want to) and the stairs take up a LOT of room - especially if you have a high ceiling.
kbs2244
It mostly depends on weather and security.
At 30 feet wide you should be able to get all the up with a single flight.
Maybe a small platform as the bottom stair.
Under the stairs is the usual place for the work bench.
So, if inside, you will not be “wasting” much space.
ddawg16
S. California
Mine are inside...spiral stair case
ddawg16
S. California
Isn't it difficult to take stuff up those stairs? Like supplies..? it would be especially difficult to take a long board of wood up those cuz of the spiral.. right?
Nope....actually real easy for long items.....just stick them up through the opening....
When we are putting a bunch of stuff up or down...my wife will be at the top...me at the bottom...I only have to go 2-3 steps up to be able to reach her...she reaches down and grabs it....
We would not do it any different.....
If it's really large....we use the 4x4 window on the side....if it's bigger than that...it shouldn't be up there.
You can see more pics by clicking on the link in my signature.
64dragnwagon
Northeastern Tennessee
I would probably go with inside. If you lay it out right as stated you can get some storage and a workbench and not lose much space. I would go traditional not spiral, also I have found in most cases that an L shape fits better and doesn't seem to get in the way as much. The last two stairs I layed out and built have been L shaped (my basement in my house and in an old carriage house I remodeled).
oldcpecdr
Cape Cod
Where do you live ?
Mine are inside, with a 12 foot ceiling it took a 90 degree turn in the corner and a landing...but takes minimal space and there is a lot of storage space under the stairs...before I moved the compressor to the second floor it used to live under the landing....
I did the trap door with a hoist for easy access for large or heavy loads. I live in New England and can't imagine outside stairs with snow and ice, but if you live in a nice warm climate with no snow outside stairs might be just fine....
Mike B
larry_g
oregon
I have had both of mine on the inside. The old shop had a false wall at he end of the loft so the pickup could back in and move from the pickup to the loft with a lot less lifting. The new shop below I can drop out the railing and lift stuff with a fork lift or the backhoe bucket.
lg
no neat sig line
KPSquared
Wetaskiwin, Alberta, Canada
I'm building my 30x36 right now and the stairs are going to be on the outside. This decision was made just because inside stairs waste so much space. I've considered adding a spiral staircase inside as well as the outside stairs just so I can go up from the garage, but that is an unlikely situation as the retrofit would **** at this point.
Our outside stairs actually are going to tie into a whole deck/boardwalk design from my shop to the house and fire pit area on the hill behind the shop.
My pros/cons:
Inside:
Pros:
- Easy access
- Don't have to go outside.
Cons:
- Waste space (upstairs and down)
Outside:
Pros:
- free up a ton of space
- quick access without walking through the shop
- just makes the most sense for my place
Cons:
- Treated lumber costs more
- more stuff to shovel in the winter
- slippery when wet with an armload of junk. . .
bobadame
I put mine outside mostly because I heat the lower space and not the top room. I didn't want to create a chimney for heat to escape. Also I made a deck at the top of stairs where it's nice to hang out and enjoy the view.
BD1
north side
I would go with inside. Don't have to be concerned about weather. Adding a outside gable end door would help to for longer stuff. Is the loft going across
the entire length ? you could even have a opening in the floor to pass material up from inside. For heavy stuff maybe get a Genie lift.
http://www.genie-lift.com/
White 99
Northern CA
I agree with what most have replyed already. I have a two car garage attached to the house and a room above with inside stairs. I probably go up there a couple times a day and some days many times; outside stairs would be pain with weather and door locks to go through.
My other garage is detached 24 x 50 and has a room above it also. It is used for storage and I probably don't go up there once a week; I have outside stairs on that one. Inside would have used up a lot of space, both upstairs and down.
Like others have said a lot depends on how much you are going to be up there.
steves29
I have outside stairs with a small deck at the door. This year I closed in under deck to match house. New home for garden tractor. The better half thinks it the potting shed.
LutzTD
Lutz, Florida
I plan to put mine outside with a swing open outer rail for getting things up to bring in with a fork truck and a solid landing to act as a rain cover for the ground floor entry door. I see very nice steel commecial stairs sets on Craigs pretty ofter for $500
HKB3
Finksburg, MD
I did not have a choice as my garage was already existing when I bought my house, I have a 2 story 24x32 with 9'6" ceiling on lower level an standard 8' ceiling upstairs. I am in the planning stages of moving the stairs which are "L" shaped from the center of the garage to run along the back & side walls. Orignally I wanted to relocate them outside but decided against it for convience and mostly cost. Once I get moving on the project I will start a thread in the gallery.
Bender78
Northwest CT
When I first built my 28 x 32 timber framed barn/garage/shop I put the stairs inside. After a couple of years the shop grew where space was a a premium and the stairs just took uo to much valuable space. They got moved outside. I love the view from the top if the stairs now, I can survey the entire property from there. I also think it gave the building more character.
W
wliggett
Thanks for all pros and cons guys. My final decision is likely going to be inside as I want to bring out water (200 ft from house) and will place the utility sink and commode under the stairs.
W
wliggett
Thanks for all the pros and cons, guys. I think I will likely go with inside as I will likely bring water out (200ft from house) and will place the utility sink and commode under the stairs. Really like the idea of an opening with a winch or block and tackle in the middle, too. :thumbup:
