Log Seats
Jmellc
Durham, NC
We just had a huge oak cut down as it was dying. Got lots of firewood from it and saved a few large chunks to make stools around a firepit later on. I'm thinking of coating them with some kind of tree sealant on the bottom and clear coating on top. Have any of you done this? What worked well for you?
mike93lx
Richmond, VA
Red oak, white oak, or some other variety? They weather very differently
Setting it up to shed water will be a huge help.
isb cornbinder
80+ year old tractor seat and still standing.
J
Jmellc
Durham, NC
Willow oak. Yes, I'm thinking of putting paver stones under them to help keep from standing in water. But still need to coat it with something.
mike93lx
Richmond, VA
I meant the seat. Make sure water can roll off. But keeping it off the soil will help too
A spar urethane would hold up OK outdoors, but if that log wasn't stabding dead for years, it's going to be wet and might shed a coating as it dries
J
Jmellc
Durham, NC
I have not looked today, but I would not be surprised if there were a few on Craigslist.
Thanks but since I already have the logs, I'd rather use them than pay 20-30 each for tractor seats. If I run across any at yard sales, etc. maybe I will buy them. But then again, I don't have welding equipment to weld them together. Much easier to use my logs than buy tractor seats and buy welding equipment.
Zewnten
My parents had benches made from halved logs. Need to shape the seat to shed water but it’ll probably start splitting anyways from absorbing the humidity alone. Varnishes and lacquers don’t seem to do much in the long run.
gahrajmahal
Cincinnati, Ohio
If you have termites they will get up into your logs. I have some that I’ve used as chopping blocks, after about 10 years or so with no care they are ready to be chopped up themselves.
You might try making some cross style legs out of pressure treated lumber if you want them to last and be less tippable.
Copymutt
Colorado
Not so humid here, but intense sun death. My default is boiled Lynn seed oil. I have a lot of faith in it compared to other products. On the high end I treat cabin wood & timbers with One Time Wood.
  • Like
Reactions: RPH
LOW1
ontario
Lots of moisture in NC. Unless it’s white oak you may well spend a lot of time working on something that might last only two or three years.
Best finish would be paint. Second might be multiple layers of marine varnish from a marine supply company, not the box store stuff.
Sand it smooth first.
bdbecker
Iowa
