Good idea.Probably depends on the design. Old school fixed wedge horizontal splitter or newer hor/vert combo with a traveling wedge and fixed foot?
I've got an old school 15ton horizontal that my folks bought when I moved out after high school and I'm 47 now. It was used then, I now have it, and splits a bunch of red oak and hickory every year. Its got a 2 stage pump and a 6 or 7hp Briggs on it and got to be 35 yrs old. You can lay a split across the grain and it will slice right through oak on the 2nd stage.
The wedge taper is sloped forward at the top so the leading edge is ahead. This helps to hold the round down so it does not fly/push off. It also has wings along the wedge side to help kick out and spread the split. I rarely need to dress the edge of the wedge with a file, but do keep it sharp.
If starting from scratch I'd seriously consider a log lift or at least a side table. I stack about 4 pallets next to mine to use as a table. Roll the big crazy rounds up on a pallet and bring them to the splitter and just roll them over. Beats lifting them.
Here is how I built mine. I also tapered the wedge based on cruising some forums and looking at various builds and also rented a splitter from Home Depot and got some dimensions from it. I built the wedge about 9 inches high but should have made it higher, probably 12 inches.
