Log Splitters
4rcFed
Pittsburgh, PA
Well, this might be the year to look into getting one. I never needed one to much, but moving back to PA, I think I might be burning more wood!:bounce:
Obviously there are splitters for sale everywhere, but which ones are the good ones, what specs on the equipment are the most crucial to look at, etc???:confused:
Any help is appreciated!
NJHandyGuy
Brick Nj baby
the ones from northern tools **** i had ot have the block end rewelded almost 3 seperate times then it would crack between the repairs arrrgggg
lilredex
Toronto
I like this approach.........has to lots of those things laying around doing nothing. The trick is to find them.
I have three and throughout the years I have had issues with all of them. But by far my son has turned out to be the best over my wife and daughter.
Sterff
PA
We have a 26 ton Brave log splitter. We split anywhere from 10-20 cords of wood per year. It has performed flawlessly with the exception of a blown hydraulic hose. That was kind of our fault though because, the wedge kept bumping the line and it wore through eventually.
Greatbear
Columbia/Fulton, MD
I have a rather nondescript 20-ton MTD I bought new over 15 years ago. Aside from one leaky fitting that I had to tighten, it has been working perfectly since day one.
4rcFed
Pittsburgh, PA
While in the process of clearing several acres, I am cutting and selling logs whole and I am keeping some for myself. Since they are green and whole, I am not asking a lot for them. But it would be nice to keep this wood, split it and sell some next year, and keep some for myself. Hence, the need for a splitter.
They aren't cheap and I don't want to buy junk, but I also don't need a $3,000 splitter.
Anyone have any experience or thoughts on the few, or others that you know of?
Home Depot Ariens 27T $1599
Lowes Troy-Bilt 27T $1299
TSC Huskee 22T $1099
PhantomEB
Medicine Hat, AB, Canuckistan
I just buy a shortbox stacked nice and neat, cut dried and split for 35 bucks, even a 2 hour drive is worth it. Cant wait til Spring when I can afford a 20 foot flatdeck and I offer the mill owner 200 bucks cash to fill both the truck and trailer, truck to even top of the box and then some, trailer will have 4 foot box sides full of wood.
RAYJAY
UNION DALE PA
moving back to PA and not going to burn coal ...............:headscrat
blstickley
Virginia
i have used the husky from TSC for around 9 years splitting wood for home, farm and to sell the only problem i have had with it is the motor was shot after about 7 years easy fix got a used push mower did the swap and its still going strong don't know about the new model from there but if its like the old one its worth the money good luck
4rcFed
Pittsburgh, PA
The place that we moved to has a fireplace, so we'll be burning wood. We have / had several acres that were wooded. I am clearing them so that we can have our horses here. So I have hundreds of trees that I am cutting up. Which means..........tons to split too!
buildmyown
Franklin Ma
Not knocking the DR unit but here is the original version of that style splitter.
http://www.supersplit.com/
I have one that is 30 years old the only thing that has been replaced is the motor its on its 3rd one. It had a Briggs the a Robbins and now a 5hp Honda. It will split anything you can lift on the beam. Faster then any hydro splittter out there unless you buy a $5,000+ Timbewolf or the like. Less moving parts then a hydro super simple machine. Mine has had a couple thousand cords through it. It was used by a friends father in a commercial firewood business for over 10 years.
Yes the price is high but it will last plus its made in the USA right in Bridgewater Ma. Paul still runs the business and if you ever need parts he is only a phone call away.
Now if you watch the videos it looks like it will only split small straight grain pieces but i can tell you first hand it will do anything. The key is to not muscle through a tough piece like you would with a hydro splitter but to start on the outside and work you way in almost like peeling an onion back. Ive split Oak Pine maple Elm Cherry Ash ect. with mine. I try not to lift anything bigger the 20" in dia just to heavy so a half or quater big logs with the saw or a maul and wedge. I can do about a cord an hour with this machine in good wood by myself.
onewaydave
Down the road from Dorothy and Toto
Until a few years ago, I used a maul. Then my brother bought me one, generic 20 ton from Tractor Supply. Works great. In fact I spent about 4 hours on it today. I've split stumps and crotches of red elm, hackberry and a lot of others. Never whimpers.
But I've gained about 50 lbs since I got it.
Dave.
larry_g
oregon
http://www.speeco.com/products.php?id=95&prod=357
I've got a speeco 34 ton, which looks to be replaced by the one in the link. It does the job for me. We have old knarly oak and maple here that can be better that 40" in diameter and in the 4 or 5 years I've owned this I can only remember a couple of times a knot stopped it. The other one that I thought of getting was the Troy-built as it is similar. So depending on your wood pay attention to the tonnage. Also pay attention to the slide, does it shed chips easily or catch them and bind up the ram.
lg
no neat sig line
Lkdelta
40 mi.east of syracuse
Borrowed a friend's..that huskee from Tractor supply
Very good working machine."The tip-up feature" makes splitting the big ones easier
FAST cycle time
The control hydraulic block/lever is in a very good spot
good gas mileage.."about 3 cord per tank"
Gas tank volume (a little more than a quart) will only last about hour though
Lots of dirt and splitter scrap pile up fast "in the tray" the knife rides in
Charles (in GA)
50 mi south of Atlanta
Try theses..............
Bobcat Log Splitter
Unicorn Log Splitter I remember seeing these advertised in Popular Mechanics in the '60's
Giant Flywheel Log Splitter
The real PRO model
Another "count your digits" when done model
Another "watch your step and don't stumble" model
I do recall seeing a lifter added to a regular hydraulic splitter. The ram operated a cable and when the ram pulled back, the lifter came up so you could just roll the log into place, then split it. When the ram was fully extended the lifter was down, and you rolled another log onto it.
Charles
TreePointer
PA
If you've cleared a lot of land or have a lot of treetops remaining from a timber harvest, then faster overall operation speed may be desirable. This is achieved with a fast cycle hydraulic model, an hydrualic model with a 4-way (or more) wedge, or a flywheel model. I'm ruling out large expensive firewood processing machines because I assume you don't want that.
There are a lot of MTD clones, which are essentially the same design (MTD, Troy-Bilt, Yardman, Cub Cadet, John Deere, et al.). I don't like these as much as some others in its class because the beam is lower (harder on the back), the log dislodger is not as beefy, it often has an half beam, cycle times are often longer, the wedge design is too wide (not a two stage like Huskee/Speeco), and the cylinder has been known to rip apart on late models.
The best bang-for-your-buck in the homeowner/entry level, IMO, is Huskee/SpeeCo (SpeeCo makes Huskee). They have a higher beam with a cradle built into the beam, the wedge design is better than MTD, and you get a full beam. I purchased the Huskee 35-ton a few years ago from TSC and have been very pleased. It goes through even the toughest crotches. Although not made in USA (only assembled) SpeeCo customer service is very good. The weak link in for Huskee splitters is final assembly at TSC--some stores do this better than others.
You pay more to top brands like Iron & Oak, Brave (made on the same line as I&O), Timberwolf, and American, but one of these may be what you need.
The I&O are really nice and are better balanced than Huskee/SpeeCo (easier to move by hand because of less tongue weight). They also make an 8 sec fast cycle hydraulic. What I don't like is that you have to pay for extras: log dislodger and log cradle.
If you have a bad back or want a 4-way splitter, look into a Timberwolf or American with a log lift and table. These models will have a stationary wedge on the beam instead of one on the hydraulic ram. You don't have the option to change the orientation of these to vertical for splitting large rounds, but that's why you get the log lift (or noodle large rounds in half with a chainsaw before putting them on the beam).
The flywheel models are very fast (~3 sec cycle times), but need a couple attempts at really tough rounds. Super Split, Wood Wolf, SpeeCo SpeedPro, and DR. These excel with striaghter wood. I've been looking at a Super Split to compliment my 35-ton vertical/horizontal hydraulic. If you're not sure about these, there are a lot of Super Split videos on the Internet.
On an hydraulic splitter, you want it to be faster than you can work. For me, I'm usually a one man operation and that's about a 14-15 sec cycle or faster.
You will have options for commercial engines on more expensive splitters.
cundifc
We had an iron and oak we split a 1000 cords of wood over the years and had no problem. I would recommend one.
TreePointer
PA
Why not cut a deal with a firewood seller, they cut and clear and you get x amount of split wood?
Youtube is crazy with wood splitters.
Whats really wrong with a cheap ($400) HF with a warranty? or rent one for a weekend.
http://www.harborfreight.com/7-ton-log-splitter-97113.html
It's a lot of work, and I'd be surprised if any seller would give you one load for every 4 loads taken. It's even more work fighting western PA hills. Of course, I guess it would depend upon how much split wood OP wants.
That HF model is electric, which means it's slow and limits your processing area to the length of extension cord. It also won't make it through the tougher rounds. You want at least a 20-ton model from a decent maker to process those treetops before they rot.
TreePointer
PA
If you're on Tractor Supply's mailing list you'll get a 10% off coupon from time to time. I used one to purchase my Huskee.
Sterff
PA
The one I showed above has filled this trailer more times than I can count. One load is about 3 3/4 cords. This was the 9th load of the year....
TAftw
Iron and Oak ones are really good, they're definitely better than MTD or the ones you get at Tractor Supply.
4rcFed
Pittsburgh, PA
I asked a few local places that have splitting machines that if I could even bring trailer loads of logs to them and they wanted no part of that. One guy said that he would take the wood if I cut it up and split it, and then brought it to him.:headscrat Yeah, ok.
Yeah, I need to keep my eye out on that one. The one I posted earlier for $1099, was $999 in last week's flyer without a coupon. Should have jumped on that.
I like that Brave unit, but I think when I looked them up, they were like $2500+. More than I care to spend right now on a splitter. Don't need the best, just need something that will work and last.
I also agree to many comments that cycle time is key. And the odd thing, I think the TSC unit had the fastest cycle time, of the three I had posted.
trbomax
starvation lake,mi.
I have the three point one from TSC and run it off the 7730JD.With that tractor running at 1200rpm it will cycle in 8-10 seconds. I have run it on the NH tc35da,but its slower,about 15 sec @ 1800rpm.I have 20' hoses on it and dont actually mount it on the tractor. It runs vertical or horizontal. I use the NH w/ bucket to haul the splits away and bring over the rounds.
