As I wallow in self pity because I can't justify the nearly two hundred dollars for the Proto 90 tooth that I want, I'm researching more affordable options.
The affordable domestic options that are currently capturing my interest are the Williams S-52EHLA and the Proto J5450XL. I've never bought any Williams tools new. But a domestic 1/2" drive ratchet for around fifty bucks sounds good. I have Proto tools and really like them. I have the 90 tooth in 3/8"drive but as I stated above, two hundred dollars is beyond my current budget. The J5450XL is far less tooth count (45) but higher tooth count than the Williams (36). I doubt clearance will be a huge issue so I'm not sure that will make any difference.
Some of you pro's and some of you home gamers know way more about this than I. I'm looking for input from folks that have actually used these tools.
Thanks
Thanks
