I have an electrician coming this week. Just thought I'd run it by the folks here.
So meter is on the pole. Service goes from the pole to the house then to a "makeshift" box out beside where the garage use to be. Inside the box is the panel shown above. I'm going to remove the cover of the panel inside the house and see if see what's going on. I'm not into this very far but I appreciate the alarming comments. LOL. Like I don't already know it's a fire hazard.Any clue where the wire coming into the panel is from?
Where is your meter in relation to this panel? Is there a breaker there?
I wonder if this a a tap...
Zim
So this is the good part. Pole and meter is 30 yards from the house
Here ya go. Remember this is farm house from 1910, modified by farmers, rednecks, drug addicts and now me so that's that. LOLThere might not be a need for ground rods. It's outside where the garage used to be, could have been an inside panel for an attached garage on the common wall, then three walls were torn down leaving the panel outside but still on the house. IF that's the case, and the main panel is in or on the house, no ground rods would be needed. If it's detached, ground rods would be needed. Since the panel is fed from the back, the feeder is going through something, if it's not a wall, I'm clueless. I would think if it were a stand alone panel, it would be fed from underground right in the bottom of the panel.
How do you know when the panel was made?they are silver now but not when that panel was made.
Zim
Odd there is a PoCo seal tag on the lower section. Is this fed from the load side of the meter/meter main? if so then there shouldnt be a PoCo tag on the lower section and I suspect there are or used to be breakers in there...
Does the feed from the outside old meter main come thru where the duct seal is on the lower left?
That's where we're headed. The house on one acre cost us less than a new pickup truck. Even a good used one so electric and garage are first on the list.honestly this entire system should be rewired and repanelled starting at the meter if you want it done right....
get a bigger meter main with enough disconnects for each building, run new 4-wire feeders and get rid of that square splice can in the middle of the yard
also replace that old sqaure D main in the house as its full and old
Thanks
Zim
Garage is going where it was before, beside the outside panel.Where you putting the garage?
One option may be to put a new meter/main there and feed the house from that, if the timing works.
We'll find out soon but you're about right!It's a mess, but I'm willing to make a wager on this is what's going on. Overhead service to the pole, from the pole overhead to the house. Out the back of the house meter main into the back of the SQD panel in the house. Out the bottom of that meter main for underground to the panel that started this thread, the breaker for it is probably in there. Cut the seal and open it up. I'd like to know how the meter socket on the house is getting bypassed; is it a real set of jumpers, a piece of smashed copper pipe shoved in the jaws, or are the conductors running through the POCO section to the panel interior?
In California used electrical equipment has to have the blessing of the AHJ to be suitable for re installation. Check with the inspection dept. first.Even a good used one so electric and garage are first on the list.
Is the fix the saw or the bubble ****?
I didn't notice the saw until you pointed it out.Is the fix the saw or the bubble ****?
I guess it depends on what needs fixin.Is the fix the saw or the bubble ****?
Yeah, we don't have that. We don't have any of that. LOL Did I tell you I can throw a rock and hit Arkansas? Our building codes are copied from typical codes around Missouri. I'm sure there are inspections for new construction but old farm houses are just forgot about.In California used electrical equipment has to have the blessing of the AHJ to be suitable for re installation. Check with the inspection dept. first.
"To be reused, salvaged panels must be reconditioned, tested, and verified to be in proper working order"
We're going to. Waiting for the electrician this week. I'll probably pull all the wire and let him do the panels. I've already installed 6 outlets myself.I would redo it all. Farm house from 1910 and lots of hack work. It’s worth spending the money on what you need an electrician to do to avoid a fire at some point. Maybe you can do some of it. People here are really knowledgeable and helpful. I wired a 1500 SF shop myself.
You can swing the cover at the bottom of the pole up without hurting anything and I bet you find a 100 amp breaker in there. Normally on an old farmhouse I'd say a pullout fuse block but that looks too new. I say 100 amp because I'll bet the line to the meter and the load to the house are both in that pipe and if it were 200 amp I doubt the conductors would fit. Since there is no meter in the box on the house, I see no reason for the POCO seals and even if there was a meter in it, you would need access to the bottom half so cut that seal and open the door, that might just have a pull out fuse block in it, might be a breaker, whatever it is, there's probably only one and the wires to the house and the wires to the outdoor panel are double tapped, but there could be a set double barreled lugs on the load side. If you're not comfortable completely opening everything up, know that there should be a cover behind both doors so you shouldn't be exposing yourself to anything bad.We're going to. Waiting for the electrician this week. I'll probably pull all the wire and let him do the panels. I've already installed 6 outlets myself.
Thanks.
Zim
which code is that?In California used electrical equipment has to have the blessing of the AHJ to be suitable for re installation. Check with the inspection dept. first.
For reuse
110.2 Approval, and 110.3 Examination.......
Although used equipment, it's a new installation.Looking quick how would that apply to (listed) used equipment?
Thanks
Zim
I think what he meant was the he bought the property for less than the price of a good used pickup truck but hit the wrong key and entered a . instead of a ,.In California used electrical equipment has to have the blessing of the AHJ to be suitable for re installation. Check with the inspection dept. first.
I agree. Those commas are important, especially if you are a Grandpa.I think what he meant was the he bought the property for less than the price of a good used pickup truck but hit the wrong key and entered a . instead of a ,.
Something something ******** a horse...I agree. Those commas are important, especially if you are a Grandpa.
Let’s eat Grandpa.
Let’s eat, Grandpa.
Commas save lives.
Can you help Jack, off a horse?Something something ******** a horse...
