vette-kid
Ive been wanting a compressor for a while now. But I dont have enough of a "NEED" to spend $400+ on a new one. Well the other day this popped up on craigslist. I was hoping for a little better condition, but for $150 I think this will serve me well. I figure if it gives me a year or two Ill be pretty happy. At that point I can reevaluate my needs and step up to something nicer if I feel its worth it.
When I got it it was covered with oil...turns out the head bolts were loose. As were the mounting bolts. So I tightened everything up and cleaned it a bit. I drained the oil and got a full quart of VERY black oil out of it. Odd thing is that when I replaced the oil it took just over half a quart to fill it. Did this guy put way too much oil in there? When I drained the tank I did get some brown sludge that came out from the drain.
I also had to replace the drain, the coupler, and the copper pipe from the pump into the tank.
Despite those issues, it runs smooth and quiet, fills quickly (took about 2 min or so to reach the 130psi), and holds pressure. I was able to fill three tires pretty quick before it kicked on, and then it only ran for about 30sec. Im not sure what most would consider that, but Im very pleased with it. Of course its my first compressor, so maybe I just dont know what good is
One more pic in its new home!
I also had to replace the drain, the coupler, and the copper pipe from the pump into the tank.Despite those issues, it runs smooth and quiet, fills quickly (took about 2 min or so to reach the 130psi), and holds pressure. I was able to fill three tires pretty quick before it kicked on, and then it only ran for about 30sec. Im not sure what most would consider that, but Im very pleased with it. Of course its my first compressor, so maybe I just dont know what good is
