lookiing for printable lug nut torque specs
kumquat
North of Montana aka Saskatchewan, Canada
BillK
Beautiful Southern Maryland
Not sure how you could really have a "printable" one. Too many variables from vehicle to vehicle. The same stud thread diameter might have 10 different torque specs depending on the vehicle it is on.
-Stew-
Tucson, AZ
Someone in the tire servicing world probably makes a nice laminated cheat sheet to hang on the wall. But with so many makes and models out there, it's hard to compile everything in one small list.
As an ASE Master Automotive Tech with L1 and L2 Advanced Level Certifications, ASE Master Truck Tech, and ASE Master Equipment Tech, I can tell you a Milwaukee 18v 1/4 inch bit driver does not provide enough torque to properly secure a wheel to a vehicle. That's a lesson you learn in the real world, not the class room.
racecougar
Missouri
Of course there are myriad variables that play into this, but speaking in generalities, this isn't bad:
Hardware Bolt or Stud SizeTypical Torque Range in Ft/LbsMinimum Number of Turns of Hardware Engagement
12 x 1.5 mm70 - 806.5
12 x 1.25 mm70 - 808
14 x 1.5 mm85 - 907.5
14 x 1.25 mm85 - 909
7/16 in.70 - 809
1/2 in.75 - 858
9/16 in.135 - 1458
-Stew-
Tucson, AZ
7/16 in.70 - 809
1/2 in.75 - 858
9/16 in.135 - 1458
That isn't relevant to lug nut torque specs.
-Stew-
Tucson, AZ
Your link isn't working for me. Here is a link to a chart with various lug nut torque specs. If you look, there is a variety of torque specs for the same diameter and thread pitch nuts based on the seating type. The original chart you posted are general torque specs for nuts and bolts. Wheels use specific fasteners and have specific torque requirements.
racecougar
Missouri
For some reason, clicking the link takes you to Tire Rack's home page. Copy/pasting the link takes you to the correct page.
BillK
Yes but it is not correct for all vehicles. My 99 Tahoe has M14 x 1.5 lugs and the torque is 140 lb. So if I look at that chart and torque them to 90 they will be woefully under tightened :( :(
Ill stick with my original answer and say the correct torque is found in the factory service manual or the owners manual. It is too important of a spec to be using a generic chart.
pbon
I agree. My 21 Porsche Cayenne and 18 BMW M5 must suffer from myriad variables because they have 14mm lug nuts that are torqued to 118 and 105 lbs respectively. My 99 BMW M3 also suffers slightly from myriad variables because its 12mm lug nuts are torqued to 88 lbs. I think that I am attracted to cars that suffer from myriad variables so I won’t use any generic torque charts.
racecougar
Missouri
I'd certainly classify those as atypical. The '21 Cayenne is either too new or too oddball for RA to even offer a lug nut or bolt (whichever it takes) for it. It looks like both the M5 and M3 use bolts, not lug nuts. Again, the chart was offered as a general guide.
Of course it isn't. It was never claimed to be.
bb29510
two grunts 40 ft pounds
two grunt and a chiiiiiit 45 ft pound
ohhhhh my god 65 ft pounds
