GophersGarage
Any idea in brands to look into ?
Both Sunex and Astro have sets worth considering. Assuming you want a deep set.
I've got this set from Sunex, 12pt deep stamped & etched for size. No issues with use.
Amazon 79$
https://smile.amazon.com/Sunex-2835-Spindle-Standard-12-Point/dp/B004IKPST6/ref=sr_1_12?dchild=1&keywords=2835+sunex&qid=1594608122&sr=8-12
Tooltopia 93$
https://www.tooltopia.com/sunex-tools-2835.aspx
Found them on amazon Canada they are 162cnd
A
Astro brand I am ready to buy are not stamped
I do want deep and 12point
Where did you hear this?
Is this because it doesn't show them stamped in the images (laser faces front)?
All the sockets are roll stamped and lasered
I don’t see stamping in picture nor does amazon description state they are stamped
Also checked questions ask and reply was they are printed
Are you confirming they are both that would be great
As a professional mechanic I have a mix matched set the ones I use most are the Husky 12 point because when I needed them that was the only brand that I could find individually besides Northern Tool. At my shop we are not allowed to use an impact on them so I have to break it loose with a breaker bar so chrome or impact doesn’t matter to me.
Sent from my iPhone using
The Garage Journal mobile app
What are you working on that's 12 point and you can't use air to break loose? Toyota axle nuts come to mind and they are 12 point, and axle nuts blow breaking loose without air. Last one I did with no air, a few weekends ago, I was standing on a Wylde pry bar, end on the ground, and using my wright railroad ratchet to break it loose. So what are you working on?
I use to work in vw they were 12point I too have used long breaker bar and big pain
Those axle bolts rust so fast even on new cars
I'm guessing it's because people forget to unstake the nut. Common mistake. I've still had stuff shred off though. One of my cars is a scion TC. Oem axle nut and axle, went to replace the wheel bearing and such, step 1 axle nut shreds axle. Step 2 get axle out. That was fun and a lesson in improv. Point is, harbor freight 12 point set, they didn't fail, the parts did, and is usually the case. I own all kinds of tools, but the hf sockets still stand up. I have others as well.
I understand axle sockets should be thinner but if they are rated impact
What can they not be used in that way ?
Lol just my boss telling us I guess lol if we do use impact and get seen or told one we are terminated on the spot
Nuts.
I suppose they prefer OSHA approved cheater pipes? (not that there's anything wrong with cheater pipes)
