Looking for a good portable butane soldering iron
oleblue
I do quite a bit of wiring and such on boats and cars mostly 14-18 gauge wire. I've been looking for a good soldering iron for a while. I like the butane powered ones since they are small and I see some of them double as a heat gun for heat shrink which is handy. Which one's are you guys using? Here is a couple of ones I was looking at.
http://www.denlorstools.com/home/dt1/page_27566/portasol_sp_1k_soldering_iron_kit.html
http://www.denlorstools.com/home/dt...e_pp_ppsk_mini_butane_soldering_iron_hot.html
route246
NorCal
I have two Portasol irons and they are my primary soldering iron of choice. It's like cordless drill drivers. Easy to use, good for small jobs and very fast heat up. The only problem I have is the cheap butane cans used for cooking need a special adapter (very thin tip), or you can just buy the expensive small cans which have the thin tip.
I think you can get a better price on amazon, but not sure.
O
oleblue
Yeah I found both cheaper on Amazon, but Denlors tools site is easier to browse when looking at different ones.
route246
NorCal
Basically, I think you will be very pleased with whatever model you get. The only time they are challenging is outside in high wind. You need to shield it from that because the flame is actually glowing inside like a glow plug once it gets up to temperature. Otherwise, they are brilliant in design and work like a champ. I think I've been using these types of irons for over 30 years. Very sound design.
scott37300
Wisconsin
I have had a portasol for about 5 years now and use it for almost everything. It's just nice to be able to move it around without cords. I also have a plug in soldering iron and gun and they never get used anymore. If the weller portasol can't handle it the hakko soldering station will take care of it.
toolfanatic
Ireland
I have an older Portasol, (which are made only 22 miles from where I live in Ireland!) and they are an excellent tool.
Skyline
I have the Powerprobe...works great. I also have one I got at Radioshack that is a pocket version. It works pretty well too, is quite a bit cheaper, ($29?) but does not come with all the accessories (just a soldering tip and a blow torch tip). The Radioshack item is red plastic, with a clear resevoir.
Lotek
Los Angeles, Ca.
I have used both, I own the Powerprobe unit, both good, the heatshrink takes a while, but for the sixe of the unit, not bad.
scott37300
Wisconsin
they don't get hot enough
What are you soldering? There are very few things I haven't been able to get hot enough. One of them being battery cell tabs when rebuilding my cordless tool batteries. Other than that they are plenty hot enough for almost any soldering in the garage.
copterdoctor
Wasilla Alaska
I've had a few blue point butane irons... they last for about a year, then **** out... I'm on #3... it's a "i have to have one for the field" type of tool for me... other wise I use my electric weller when I'm in the hangar..
DHCrocks
Hawaii
I have a portasol and like it a lot it's so convenient. For the most part it gets plenty hot and will easily melt the solder, but I have noticed that if I'm outdoors and theres a light breeze then yes it does not get hot enough. It's kinda strange because if I use my electric iron it gets hot but not the butane one.
O
oleblue
I see that the portasol is 25-125 watts, anyone know what the power probe wattage is? I think I've decided on the portasol iron.
