Looking for a good T30 Torx socket, any recommendations?
jgelack
Hi, I need to purchase a good T30 Torx socket to remove the stator bolts from the OEM cover on my motorcycle that won't strip them out, and was wondering if you guys had any suggestions. I'm planning on heating the bolts first, then using the Torx socket with either a ratchet or impact driver to loosen the bolts. I'd really appreciate any advice you guys could give me. Thanks again!
KBigg
NE Indiana
Carlyle impact torx seem to hold up well. I used mine with a manual impact driver to remove the rusted seat bolts in my old k1500
_Riddle
Storms End
Capri makes a good set you can find on Amazon, Neiko also makes a set that works well. I've used both brands on my VW which has a lot of Torx fasteners which haven't been stripped by either brands. VIM also makes a great stubby torx set that I've been wanting to pick up.
Dave455
Sussex, England
Snap On are pretty decent, as you would expect.
I tend to use Hazet a lot, as their torx and hex bits seem to be about the toughest out there, but I’m in the U.K. where Hazet are a lot cheaper then Snap On.
Another good option are KoKen, which tend to be reasonably priced.
The above are made in the U.S.A, Germany and Japan respectively. A lot of other torx bits tend to be made in Taiwan. While Taiwanese tools have improved enormously over the years, I find that these bits are one type of tool where the Taiwanese seem to struggle with making tools that don’t twist, so I’d avoid them in this case!
If you are using an impact driver, make sure you get a bit designed for impact use, or even the best quality will twist!
2ndGearRubber
Pittsburgh
VIM would be my first choice. Low profile means you are less likely to pull off center line with your ratchet. Many of their sets are impact rated too.
Yarpo
Minnesota
VIM, Capri, Gearwrench, Carlyle, I've used the first three and am very pleased, I have a Tekton set at home and they look fine too, just haven't used them much at all so I can't comment on how well they'd hold up quite yet. Snap-Ons are also great, but spendy.
Jtels85
Look up a seller called Sellular216 on eBay. He sells new old stock NAPA Auto parts tools, pre-Carlyle.
He has a comprehensive 36 Pc. Torx socket set (rebranded Gearwrench) for $39.99 + shipping. I’ve had my set for nearly 3 years and they’ve served me very well, of excellent quality!
kb1982
Kentucky
I would get a manual impact driver that you smack with a hammer and a bit to go with it.
Sent from my LML713DL using Tapatalk
vssjim
McLean Va.
SK are good for hand tool use and the Astro impact set are real tough with power tools or impact driver
FSrepair&fabrication
maryland
I would say buy snap on for anything critical. Their gold torx seem to be the best out of what ive used. Also, a manual impact driver and some heat wont hurt. you just dont want it to break. Stripped out can be handled, beat another allen or torx size into the hole and use more heat, or hammer an extractor socket over it. Broken off can be a whole nother problem.
2ndGearRubber
Pittsburgh
Try VIM. I would put them above the standard snap on torx for sure. The gold "HD Removal" bits I have seem to wear more than VIM, but have not become worthless yet. I do replace the bits from time to time in the smaller sizes. I pretty much always grab the VIMs now, unless the stubby design of their products gives me issues with fitting around obstructions. VIM being stubby also give a huge advantage in helping you pull perpendicular to the fastener. The further the drive handle is from the fastener (due to extensions or bit length) the greater the odds of slipping due to improper engagement angle.
plinker
Northern Wi
Vim & Snap-on work well, I have an older Napa/Danaher USA set that have done well. Keep in mind any brand can or will break at any time.
Jtels85
$31.50 for 1 (ONE) Torx socket?
That thing better come with a free wrister
3footpipe
N.E. Nebraska
I just bought a set of these. I have only used the torx 40 for one job. I don't know how they will hold up yet. They are impact rated and the price isn't bad.
NPT 610318 Socket Set, Internal Star, Carlyle - T20, T25, T27, T30, T40, T45, T47, T50, T55
[https://www.napaonline.com/en/p/NPT610318
NWMDC
J
jgelack
Thanks for the advice guys, I ended up picking up a set of the Stubby VIMs
