There are more expensive strippers out there but I like the
Ideal T6 strippers.
I also have a pair of their T5 strippers for heavier wire.
For crimpers, I just use an
Ideal Multi-Crimp Tool
(don't use the wire strippers on this tool ; they stink)
Ratchet crimpers are overkill for automotive wiring. What is important is that the crimper has an anvil for insulated and non insulated connectors.
I do not like insulated connectors. I think they do a poor job of insulating.
Non-insulated connectors with heat shrink tube give you more protection from shorts and IMHO looks better. The best non-insulated connectors I have used are
Tyco Electric (formerly Amp) Solistrand. They come in ring, hook, spade and **** splices. You won't find them at HD or Lowes or an auto parts store, but any electronic warehouse
(DigiKey, Mouser, Allide, Newark) will have them.
Finally, especially if it is for a motorcycle, get marine heat shrink. It has a soft inner lining that melts into the connection to make it pretty much water waterproof. You will only need about 3 sizes, so spend a few extra bucks. You can find it on eBay or, again, electronic supply houses.
I will also go out on a limb and say, if you are using marine heat shrink tube,
skip the **** splices and soldering. For 14 - 20 gauge wire, strip about 1" from each end and twist the bare copper together, at least 2 full turns, and cover with marine heat shrink. If you want "insurance", use 2 layers of heat shrink, the second one at least 1" longer on each side.
