I've been looking for some time, but haven't found anything small enough. I don't need a large break and shear right now. I'm making small 1/8th inch thick x 3/4 inch aluminum brackets and need something to accurately bend and cut. Any suggestions would be appriciated. Right now I'm using a miter saw to cut and a vice and dead blow hammer to bend
Thanks,
Dan
Yeah, but to cut and bend the material you describe requires pretty stout tooling... the el cheapo stuff at the Chinese Tool Store ain't gonna do the job.
Once in a while, small benchtop shears and brakes meade by DiAcro show up on eBay that would be perfect for what you are describing, but the normal asking price is around $1k for each.
Another item, depending on the accuracy of the bend that is needed, would be a Strapmaster (AKA Bohn-Combi):
http://eaglemorlin.com/strapmaster.html
This type of tool is quite a bit cheaper (less than $800 new), and also shows up on eBay for under $300 frequently. Be warned, if abused and bought used, they are pretty much junk.
