txvwnut
This is what I've been using for last decade or so, https://www.brakebleeder.com/products/best-sellers/v12-reverse-brake-bleeder/
I had a motive pump and a mityvac and I just gravity bleed. Really nice to lift the car and use a few feet of clear hose.
I'm not sure if Motive fixed this or not, but after a few years, all the hoses crumbled from being exposed to brake fluid. Luckily I didn't find out by spraying the car with brake fluid.
Correct. Brake fluid is actually pretty nasty stuff. If it can remove paint, and it does, Tygon tubing isn't going to have much of a chance long term so that's a very good suggestion.I also saw that Motive’s instructions say to use denatured alcohol to clean the lines, pump, etc after use.
This......open the bleeders and hope it bleeds itself.Gravity bleed
These guys in Canada make the best DIY brake bleeder. Much superior to the Motive due to the superior master cylinder caps. Especially for Toyota which is a problem child for the Motive. https://www.speedibleed.com/about_us.html
I have a motive and the hose blew a small leak a few years ago and made a big mess. It was probably close to 10 years old.I'm not sure if Motive fixed this or not, but after a few years, all the hoses crumbled from being exposed to brake fluid. Luckily I didn't find out by spraying the car with brake fluid.
I like the remote viewing idea, but with the long clear hose looped over a ladder you wouldn’t need a camera or a check valve for bleeding the brakes.Part one of my brake bleeding setup is a bottle, tubing, and check valve. Standard “one man” bleeding kit I’ve had for decades. Was always frustrating to use, because if I’m in the car pumping the pedal, I can’t see what’s going on at the wheel.
Part two solved this. I took a discarded microphone stand, and mounted a phone holder to it. This allows me to stick my phone in the wheelwell with the camera pointed at the bleeder. Then I FaceTime my iPad and put it in the car where I can see it. Perfect remote view of what’s going on at the wheel while my foot is pumping the pedal.
This setup turns out to be remarkably useful for other places, like wanting to see the spark tester under hood while in the driver seat turning the key to crank the engine.
Why waste $50 plus shipping for the Power Probe cap (which I don't think they make at the present time) when you can buy the one I suggested and it comes with the metal cap ready to roll?I was going to supplement the system with the Power Probe BA10 cap for Toyotas.
+1Jar full of brake fluid with a clear rubber hose submerged in it has always worked for me,but I'm cheap. Hahaha
Would love to see that. How can you damage a one way valve when you are sucking fluid the same direction a pressure bleeder or for that matter a normal system pushes fluid? They both push/pull fluid from master cylinder to caliper in the same direction. And what one way valve are you referring to that vacuuming fluid damages?To all the vacuum bleeding method guys,I don't know if it's just CYA lawyer speak or if there is any validity to the claims that applying a vacuum to the brake bleeder can damage one way hydraulic system seals, so I stick with power bleeding, gave up on the 2 person pedal pump process to preserve my marriage.
I would have to dig up the reference but I know that it's in at least one of my GM shop manuals.
You are correct, I think that l was thinking of the Phoenix brake bleeder that injects fluid via the bleeders and it's potential to damage ABS solenoids. I am going to blame this brain fart on getting old.Would love to see that. How can you damage a one way valve when you are sucking fluid the same direction a pressure bleeder or for that matter a normal system pushes fluid? They both push/pull fluid from master cylinder to caliper in the same direction. And what one way valve are you referring to that vacuuming fluid damages?
motive sells bottles to catch fluid and have for a long timeI use a motive but really should buy one of those allstar bottles to reduce the mess.
My last kid is still at home. He has been helping me to bleed brakes since he was like 5-6. I guess when he is out of the nest I'll teach my wife. Ha, who are we kidding? I will ask a friend to stop by.Fleet is Ford, GM and Toyota.
X2 on my wife pushing the pedal for me but that's not the norm as the shop is further out now.
The shops that had the ball bleeders never cleaned them. If your bleeder has no diaphragm, no issues if you have an air dryer.I have always been concerned that the home power bleeder is pumping damp compressed air directly over the new brake fluid
