Looking for a particular bolt
jimy
I am restoring two old “wrought iron” chairs. There was no “seat” for the chairs so I used some nice plywood and put on some stain and poly. It looks pretty nice.
I happened to have one bolt in my junk drawer I like. I will need eight of them to do the chairs. From above, it looks like a carriage bolt, but it does not have the square section. Under the bolt head are a couple of raised sections that press into the wood to keep the bolt from spinning.
Any idea where to get bolts like this? Worst case I could use a carriage bolt and perhaps grind the square part off.
My bolt is about 3/16” x 1-1/8” in length.
Thanks,
Jim
no704
That’s an off the shelf bolt, can’t remember the exact name.
BillK
Beautiful Southern Maryland
How thick is your plywood seat ? I would just get carriage bolts and drill a slightly larger countersunk hole for the square part to go into. Home Depot or Lowes should have something that will work.
J
jimy
The fin neck bolt would have worked well.
I ended up ordering stainless carriage bolts. They should work fine.
Thanks!
Jim
evildky
Louisville, KY
Home depot and Lowes both have a section fo their hardware drawers dedicated to "Furniture hardware". lots of oddball specialty hardware used in modern flat pack furniture.
